Bending handlebars
Old Feb 22, 2021 | 09:29 AM
maxxym's Avatar
maxxym
Default Bending handlebars
This will probably be strange question, but, is there a possibility to bend handlebars that are already on a bike? I have Twin Peaks 10 inch mini apes installed by the previous owner. I like them, but I wish the grips were little closer to me. I didn't know if there was a way to bend them back a little. I don't see any more room to bring them forward, since they are already at the absolute minimum to the tank when turned full.
Can this be done? Can this be done on a bike without removing everything?
Old Feb 22, 2021 | 09:35 AM
golfblues's Avatar
golfblues
I'm a little confused as you stated you don't see any room to bring them forward. I think you meant back to the rider.. if they just about hitting the tank at full turn you are maxed out as close as you could get them. Bending the bars is not an option on the bike. Time for new reduced reach bars.
Old Feb 22, 2021 | 09:45 AM
maxxym's Avatar
maxxym
Yeah, sorry, I meant bringing them back to me a little. Damn, I kind of thought that would be the answer. Oh well. It's not bad now, I just wish they were little bit closer to me.
Old Feb 22, 2021 | 10:05 AM
todd-67's Avatar
todd-67
It's winter here take your time and swap them out with something that is more comfortable for you. If the PO put bars on there they may have the extension on the wiring and other controls which is half the battle.
Bars and seats can make or break your riding experience if you are always fighting them. From the sounds of it they are not that bad for you but that is something that only you can decide. Just get a quote for switching them out at the dealer and I bet they get more comfortable.
Old Feb 22, 2021 | 10:06 AM
twincam10353's Avatar
twincam10353
Have you tried loosening the clamp and pulling the bars back?
Old Feb 22, 2021 | 10:13 AM
NoRegerts's Avatar
NoRegerts
twincam, he can't the bars are back as far as they will go. The bend at the base of the bars will start hitting the tank before anything else does.
maxxym, what you're asking makes perfect sense, but no, I wouldn't recommend it, not that it can't be done. The cost associated with that would be nearly as much as different bars. I just got the KST 12s on my bike last night and pulled them back to reduce my reach. I was told the 12s had more pullback than the 10s do. You may have to consider reduced reach bars depending on how much you need to come back. I'm 6ft and have long arms, but I have a Mustang Super Solo that moved me back almost 2in, so that's why I pulled my bars back a little.
Old Feb 22, 2021 | 11:15 AM
maxxym's Avatar
maxxym
Thanks for your replies guys. They are not really bad. I do like them, but if they were like an inch or 2 closer, it would make it better. I was hoping they could be bent on the top part towards me a little bit. I have no problems reaching them now, even though I am built like Trex lol I think 10 inch is as high I would go.
Old Feb 22, 2021 | 11:43 AM
eighteight's Avatar
eighteight
Neighbor was 6-6 , we tweaked them forward at the bar “wrist” for more knee clearance
We did however remove them from the bike
( 05 RK Custom)
Old Feb 22, 2021 | 12:56 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I have bent handlebars to fit, and generally would not recommend it.
Handlebars are stout. Bending them requires a good bit of force, which often scars the bars.
The handlebars often kink where you bend them.
The chrome will crack at the bends.
It’s surprisingly difficult to get both sides to match.
Heat certainly helps the bending process, but the discoloration is permanent.
Old Feb 22, 2021 | 01:10 PM
twincam10353
I don't think the OP really knows that. To someone as inexperienced as he is, it can be easy to jump to the conclusion that the bars are as close to the tank as possible while fully turned left or right. Think about it, they will always LOOK very close while fully turned no matter what. On top of that, when you pull bars back the majority of the movement will be at the highest point, with minimal movement occurring at the bottom.
