2000 King replacement carbs.
Old Mar 12, 2021 | 04:52 PM
Dano523's Avatar
Dano523
Ditto, stay with the Harley Constant Velocity carb, since it will give you the best gas mileage, and already set up to altitude adjust on it own.
As for tires, rip the old rock hard D402's off the bike since they are just going to cause some handling problems and even worse in the road ruts/ seams with the age of them, and install a set of Commander II's on the bike.
Note: Not the Commander III's, but search to find a set of the older Commander II's. If you can not find a set of II's, then look for a set of Ae's.
How even new 402's act in ruts and seam (white knuckling it), verses the II's or even AE's, is night and day difference.
Old Mar 13, 2021 | 06:39 AM
euchre98's Avatar
euchre98
+1 The CV is the right carb for stock.
You could do engine mods adding 30hp and still not exceed the ability of the CV to supply fuel and air
Nice stock survivor bike and you say “not looking for speed “
put it in a 45 pilot jet to alleviate epa lean tuning ( if it doesn’t already have it)
Leave that carb on it
jmo
Old Mar 13, 2021 | 03:10 PM
Dano523's Avatar
Dano523
To add, when you go to rebuild the CV carb, don't get sucked into the over price tune kits.
All you need is slightly larger main jet and idle jet, and maybe, #4 brass washer if you need to raise the needle/can go with the replacement OEM needle if you need rich up the mid range as the slide is coming up.
straightleg
Motorcycles For Sale
Aug 25, 2015 11:20 PM
nepaevo
Jan 5, 2010 11:44 AM
nepaevo
Sep 22, 2009 09:38 AM
Jumpman
Mar 8, 2009 10:19 PM
gooberhd1
Nov 7, 2007 11:51 AM
