2016 Road Glide
Old Feb 24, 2021 | 01:01 PM
Jeffstaceys's Avatar
Jeffstaceys
Stage I
Default 2016 Road Glide
I have purchased a 2016 road glide that the right hand control switch was not working, I bought the bike and a new switch and jumper wire but I still do not have power to the switch housing, none of the buttons work, the radio, turn signal, the brake light switch. Anyone else had this issue? I have been chasing ground wires and have swapped the ecm and bcm in another bike and it starts with no issues. I don’t see and cuts or damage to the harness and searched the manual trying to find the issue. Thanks for any help.
Old Feb 24, 2021 | 01:17 PM
NoRegerts's Avatar
NoRegerts
Hopefully you checked this already... Are the wires plugged in under the fairing? Fuses?
Old Feb 24, 2021 | 01:21 PM
GearheadMike's Avatar
GearheadMike
As far as 'power', you won't see 12 volts there, it is CANBUS. Check continuity through all the harness and connectors with an ohm meter. If that checks out, it can only be the BCM or the switch pack, which is the most likely. It is easy to swap out with another bike if you have one. Pay close attention to where the wires go from the switch, into the bars. They often get pinched (grounded) there, when the switch is mounted to the bars, or rotated too far.
Old Feb 24, 2021 | 03:00 PM
scott_0's Avatar
scott_0
does it have different bars on it? maybe the PO bitched the job up...
RevelatorAlf
2018+ Softail Models
Oct 25, 2020 02:31 AM
Don R
EVO
Jun 11, 2020 03:07 PM
kyle31490
Electrical/Lighting/Alarm
Apr 26, 2014 10:33 AM
big TYME
Apr 15, 2013 10:30 AM
