Sunpie headlight question.
Old Mar 26, 2021 | 04:15 PM
426power's Avatar
426power
Default Sunpie headlight question.
I installed my Sunpie headlight in my 2014 Streetglide. The light seems like it is on high beam all the time. When I push the high beam switch the light come on on the gage but the light does not get any brighter or the cut off line doesn’t seem to raise anyone have this problem.
Old Mar 26, 2021 | 04:23 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
yep, you got what you paid for.
They aim VERY high, there is no way to get them down, the high beam could be used as a Bat Signal
Old Mar 26, 2021 | 04:30 PM
426power's Avatar
426power
that is not the issue. The light does not get brighter and the cut off line does not change when I hit the high beam switch.
Old Mar 26, 2021 | 04:38 PM
GalvTexGuy's Avatar
GalvTexGuy
Did you test it by shining on a garage door or a wall? If so, and it still exhibits the same behavior, I’d say you have a defective headlight.
Old Mar 26, 2021 | 07:31 PM
RFG7680's Avatar
RFG7680
Have a Sunpie in the wife's Freewheeler, sons Dyna, sons new Sporty and installed them in a few friends bikes. All work perfectly. Sounds like you have a defective unit. As far as the "get what you pay for" comment. 450.00 for the HD one? I think not. Send it back.
Old Mar 26, 2021 | 07:43 PM
702's Avatar
702
Have you verified that the headlight you removed worked on both hi & low?
Old Mar 26, 2021 | 08:00 PM
btsom's Avatar
btsom
Have you looked at the light itself to see if the second light source NOT on in low beam actually lights up when hi beam is selected? If it doesn't start there to figure out what is wrong. Check power to the high beam wire when high beam is selected If the second light source lights when high beam is selected, your wiring is good and the light is aimed wrong internally. If you don't have power to the high beam contact in the plug, trouble shoot that problem. Have you verified the ground wire is well grounded? Are BOTH low and high light sources on all the time? Again, check the plug for proper power separation and if the wiring to the plug is functioning properly, the light assembly has in internal wiring/power distribution problem (faulty).
Old Mar 26, 2021 | 08:18 PM
kel03's Avatar
kel03
I've had them for 3 years now, works fine, never had an issue with them.
Old Mar 26, 2021 | 08:41 PM
Thatdude596's Avatar
Thatdude596
Do you have it hooked up correctly. Many reverse the polarity when swapping
Old Mar 26, 2021 | 08:45 PM
TriGeezer's Avatar
TriGeezer
Buy Chinese knockoffs. The job you kill maybe your own. Oh yeah, to make a positive contribution to this thread, I have no suggestion.
