jiffy stand
Old Aug 2, 2007 | 09:57 AM
vailtl's Avatar
vailtl
Default jiffy stand
A guy I work with just had a street glide delivered last night.
He is a bit over weight and his legs are a bit short.
He stands about 5' 8"
He is complaining about the jiffy stand being to far forward.
He is having trouble reaching it when he first gets on.
He has not much trouble deploying it just the opposite.
Do they make and extension for jiffy stands?
Thanks
Old Aug 2, 2007 | 10:03 AM
Smitty0128's Avatar
Smitty0128
Default RE: jiffy stand
they do! but, not sure its goign to help that situation as you explain it.
maybe a center stand option is better. those are out and becoming popular
Old Aug 2, 2007 | 10:26 AM
Smitty0128's Avatar
Smitty0128
http://www.ridegear.com/rg/item/F-49..._pc=GBProducts
http://www.wheeldock.com/prod_EZ.asp
Old Aug 2, 2007 | 10:28 AM
Rick51's Avatar
Rick51
Account Deactivated
HEY!!!!!!!!!! you just described me! If he has a problem with the jiffy stand have him slide forward, lift the jiffy stand then slide back. Works for me.
ORIGINAL: vailtl
Thanks
Old Aug 2, 2007 | 10:31 AM
beemer737's Avatar
beemer737
there is a jiffy stand attachment, forget what its called, it has an arm that goes up about 6 inches, I'm 6'1" and have it.
Hdbiker1450's Avatar
Hdbiker1450
So you shorter folks, help me out. Michelle is 5'2" on a good day and always needs help reaching things. She says she's only short on one end. Which end is it?!?
Old Aug 2, 2007 | 12:37 PM
Smitty0128's Avatar
Smitty0128
ORIGINAL: Hdbiker1450
i am still trying to figure out the "two trains leave at the same time....." question from 5th grade.
I will get back to you on that. In the time being get a step stool for her
Old Aug 2, 2007 | 06:12 PM
Ron H's Avatar
Ron H
I have the same problem. I'm 5'7" with short legs. The jiffy stand extension that H-D sells only helps when you're trying to pu the stand down. I won't help at all when you're trying to pull it back up. What helped me was to bend the flange up so that it's higher, and I can snag -- with a concerted effort -- that flange and then pull the stand up. A center stand might be a good alternative.
Old Aug 2, 2007 | 06:55 PM
kjunguy's Avatar
kjunguy
I have the extenstion and still had the same problem, hard to reach to pick up the stand. My solution was pretty easy. After I get on the bike and stand it upright I lift the left floorboard with my foot and THEN reach for the jiffy stand. Lifting the floorboard out of the way makes it a whole lot easier. Hope this helps.
Old Aug 2, 2007 | 06:59 PM
rickoshay45's Avatar
rickoshay45
I'm 5'6" with a 28" inseam. What I do is start the bike, take the weight off the jiffy stand, leave just touching and ease froward, then pull it up. With a little practice it works really well.
