Throttle Issues!!
Old Apr 1, 2021 | 08:39 PM
JHarley2013's Avatar
JHarley2013
2nd Gear
Default Throttle Issues!!
I recently installed new bars on my 2011 SG. I ended up soldering the TBW and upon startup after reinstalling the bars the bike was held at wide open throttle but when I twist it, it DECELERATES. Would resetting the tps fix this? Im starting to think I soldered something backwards :/
Old Apr 1, 2021 | 08:50 PM
langwilliams's Avatar
langwilliams
there are redundant wires....one set out of the black wrap an one out of the yellow (I think) you have to match it up.
https://www.roadglide.org/threads/ho...l-wiring.5897/
I did this an continued to have minor problems. If I twisted the bars to lock an pulled back on the bike it would trip a CEL. I replaced the senor with a new one an an got the same result. Looks like I have a bad connector in the connector at the frame neck that goes to the throttle body. I got new pins an the crimping tool but haven't tackled it yet.
https://www.roadglide.org/threads/not-my-day.16239/
Old Apr 1, 2021 | 09:05 PM
chopper_man's Avatar
chopper_man
There is an exact same symptoms thread in these forums. Search and ye shall find. Reversed wires.
Old Apr 2, 2021 | 04:19 AM
30glock's Avatar
30glock
Check the wiring on your switch packs, look for any exposure, bare wiring making contact with bars will do this, loosen the switch packs and see if it corrects itself.
Marshalljc
2014-2024 Touring Models
Jun 9, 2020 10:21 PM
dibdob69
Apr 17, 2017 05:35 AM
Mgrasso211
Dec 21, 2016 03:08 PM
BrysZ
Apr 5, 2015 04:15 PM
pounder35
Dec 7, 2007 08:28 AM
