Throttle lag
Old Apr 9, 2021 | 03:00 PM
pyuchem's Avatar
pyuchem
Thank you. I contacted V&H they said unfortunately throttlepak is no longer available.
Old Apr 9, 2021 | 07:26 PM
Sparkee...'s Avatar
Sparkee...
I think the setting you're looking for is "Throttle Progressively". I believe most tuners will have it by one name or another for throttle by wire bikes. I played with it a while back when I had my 13 EGlide. The idea is to soften the throttle at lower RPMs but still give full throttle at higher throttle positions. Increasing the values at lower grip throttle positions did give me the impression of increased performance, but it was way too jerky when putting around parking lots. I put it back to factory default settings soon after.
Old Apr 9, 2021 | 07:42 PM
Uncle Larry's Avatar
Uncle Larry
Figures :<(
Old Apr 10, 2021 | 01:03 AM
Dynamick's Avatar
Dynamick
Their newer tuner, the FP3, also allows you to adjust throttle sensitivity
Old Apr 10, 2021 | 08:50 AM
EdwardK's Avatar
EdwardK
As Sparkee mentioned, zero lag on a TBW bike is going to be very jerky/touchy. Every bump you hit is going to create throttle input.
And as BTSOM said, they don't go wide open immediately if you are in lower RPMs. This is done to maintain intake velocity into the cylinders and it helps the rpm's to increase faster. If it went wide open immediately at lower rpm's, it would bog down first then climb slower
Rusty19MCSFV
Oct 21, 2014 08:07 PM
ije
Apr 14, 2014 07:47 AM
sstlcm08
Jan 23, 2011 12:20 PM
stephenabel
Dec 19, 2010 07:09 PM
veeman129
May 9, 2007 01:31 PM
