tread depth questions
Old Apr 22, 2021 | 11:49 AM
JONNIEROCK's Avatar
JONNIEROCK
Originally Posted by mazz
i have 11000 miles on my third set of Dunlop [OEM] tires on 2017 CVO limited . i have 9 mm tread depth on rear tire and 7mm on front tire. That seams to good to be true i recall worst case tires must be replaced at 2 or 3 mm . How many miles do i have left on these tires?
Mazz
What I do is measure the depth. Deduct that from new specs. Then figure out how many miles per 1/32" I'm getting, then you can come close to how many miles you have left. Works pretty good for me.
According to Dunlop's website, tread depth on your OE tires when new:
Front...5/32"
Rear...10/32"
Old Apr 22, 2021 | 02:40 PM
btsom's Avatar
btsom
Re the above post, remember that replacement is recommended when tread depth is 1/32 (tread wear indicators) so that means for a front tire you only have 4/32 of wear available and for the rear, only 9/32. If you do your math based on tread depth new without subtracting the 1/32, you will be calculating miles to a bald tire. Slicks may be fine on dry pavement, but if you ever get caught in the rain or ever run through a wet spot, LOOK OUT!
REGGAEX
2014-2024 Touring Models
Sep 3, 2017 08:05 AM
Wayne Carlton
11
Aug 1, 2014 01:51 PM
Wildon883R
Sep 22, 2012 11:20 PM
blackharley32
Mar 19, 2012 12:58 PM
Throwback
Nov 1, 2011 11:47 AM
