Cuts out when accelerating
Old Jun 8, 2021 | 07:42 PM
MyFavRk's Avatar
MyFavRk
I'm wondering about the crank sensor , symptoms are similar and sometimes won't even throw a code , could replace that and see , cheap enough .
Also , if it's possible , check the fuel pressure , should be approx 55 to 60 psi , you may only need a new regulator , #10
I'm not sure if you've checked or not , but the idle speed actuator could be the issue as well , could try cleaning it with some tb cleaner and see if the condition improves . I'm not very familiar with them , but I'm guessing cleaning that would be the same as cleaning the iac on mine . #16
https://partsfinder.onlinemicrofiche...UEL%20INJECTED
Old Jun 9, 2021 | 05:12 AM
Stiggy's Avatar
Stiggy
The HD service departments used a "Scanalyzer" (sp?) to read the codes of MM injected bikes and as I understand it, some of the later diagnostic tools could still read the MM system too. Call a dealership and see if they still have the capability to plug an '01 bike in for you? (I did it once and they charged me about $65,)
Old Jun 10, 2021 | 12:16 AM
Mr. Mike's Avatar
Mr. Mike
“Any ideas?”
Uhhhhhh bad MAP sensor would produce backfire, hesitation and overall crappy operation.
Seems you’ve covered a lot of ground on this one, but trouble persists.
I tried an aftermarket MAP that “supposedly” fit my model, but the fluted rubber plug didn’t fit snug like the OEM one did.
Old Jun 10, 2021 | 09:36 PM
SnapBack's Avatar
SnapBack
Default Think I bout got it!
So turns out it was check valve line goin from filter to check valve. Received the new one I ordered and switched out old set today. Put in fresh gas primed the lines and it fired right up accelerated good but wouldn’t you know it I look down and the return line check valve is leaking like a son of a b*#%Ľ so now I have to rebuild or replace that before I can actually ride so that sucks a$$ but hey I’m 99% sure I fixed the problem. I won’t know for sure till I ride it. I appriciate all the help. Could not have done it with out y’all thanx again
Old Jun 12, 2021 | 06:16 PM
SnapBack's Avatar
SnapBack
So I rode a couple miles and plugs fouled. Replaced plugs, bike ran great for about 8 more miles then started bogging down when throttled until it finally died and wont start once again. Had to trailer it home last night and haven’t had a chance to look at it yet. I’m so frustrated with this sh$@
Old Jun 13, 2021 | 08:23 AM
MyFavRk's Avatar
MyFavRk
I understand your frustration , been there , be patient , it'll come to you . Some of the most frustrating repairs have taught me more than the easy fix's . It's a great feeling when you finally get it solved on your own , and then be able to pass the knowledge on to someone else .
Take another look at your fuel connections and make sure the quick connects are fully seated , o-ring didn't bind inside , put a little engine oil on them will help making the install easier .
Old Jun 13, 2021 | 01:38 PM
woodthumb2's Avatar
woodthumb2
start with the cheap and easy stuff next... plugs and wires... btw... no on seafoam.. just mho
Old Apr 18, 2022 | 06:25 AM
pstolz's Avatar
pstolz
Stage III
Any luck, SnapBack?
I have the same issue on my ‘91 Softail…
blknslvr
May 16, 2021 11:25 AM
Sean Ferg
Aug 7, 2012 08:37 PM
wwalton259
Apr 24, 2011 07:10 AM
deacon11420
Jun 4, 2008 12:24 PM
