Header Pipe Cracked / busted...
Old May 9, 2021 | 12:35 PM
Birdhaus's Avatar
Birdhaus
3rd Gear
Default Header Pipe Cracked / busted...
FLHTCI / 2006 / Rear cylinder header pipe has a gaping crack at the junction. I'm considering all kinds of replacement repairs. Anyone have any sage advice or experience with this issue, including a retune if I change from OEM pipes?? At this second, I'm contemplating Cobra True Duals to replace the system, currently running cobra tri-ovals as slip-ons.
thanks in advance.
Old May 9, 2021 | 12:36 PM
dawg's Avatar
dawg
Happened frequently on the twin cams. Header would crack in the junction as would the little piece that holds it atop the starter.
Old May 9, 2021 | 12:43 PM
WP50's Avatar
WP50
I used this awhile back.
Worked out good on my 08 UC
https://fullsac.com/product/true-dua...8-flh-touring/
WP
Old May 9, 2021 | 03:47 PM
roussfam's Avatar
roussfam
I used the Fullsac on my 03 Bagger. Running Cobta True Duals on my 07
Old May 9, 2021 | 04:10 PM
MURPHCC1's Avatar
MURPHCC1
STILL using the Fulsac duals (5 years now).....taking them off this week for S&S POwertune Duals.
Old May 9, 2021 | 09:24 PM
I Like Pie's Avatar
I Like Pie
I had mine welded and added a support member. I also replaced the bracket tab that attaches to the starter and torca clamp. It’s held for 6000 miles.
Old May 10, 2021 | 02:43 PM
FUJILICIOUS's Avatar
FUJILICIOUS
It happened on my 03 RK...had it welded. It held until a buddy went true duals on his 05 RK and gave me his OEM set.
I guess your options are:
1. weld it...temp fixes are just that....temporary.
2. hunt down a set from someone else selling theirs.
3. replace with OEM or aftermarket, if you were already considering going down that road.
Old May 10, 2021 | 05:27 PM
booze hound's Avatar
booze hound
I put V&H Tru Duals on my '04 RK.........no problems with about 50k miles and still look great
Good luck
Old May 10, 2021 | 07:09 PM
peterllo's Avatar
peterllo
Default Cracked header
Same in.my 07. Dealer said its a common problem. I felt the VH pipes and stage 1 kit might have contributed with higher pressures. Went to the V&H true duals, problem solved.
The second part of you problem, a tune. You don't need a tune for pipes or an air cleaner as the volume of air in/exhaust out hasn't changed. Now if you're doing TB as part of your upgrades that is a different story and you need one.. can't help you there as my bike had the SE Pro pre EPA tune.
Good luck
Old May 11, 2021 | 09:45 AM
LazySundays's Avatar
LazySundays
thanks in advance.
Another option I haven's seen metioned is the Power-Tune Duals from S&S or the Khrome Werks equivalent to that setup. They run the rear pipe under the frame like the newer bikes and have a small crossover section that is supposed to eliminate the torque loss from true duals.
GregGillette
Exhaust System Topics
Jan 29, 2017 09:44 PM
timber0472
May 23, 2015 10:25 PM
BNAllen
Mar 12, 2012 06:53 AM
NiteOwl
Jan 30, 2011 09:31 AM
dgriffith
Sep 20, 2006 04:57 PM
