2009 Electra engine oil
Old May 16, 2021 | 12:55 PM
Lunchbx13's Avatar
Lunchbx13
5th Gear
Default 2009 Electra engine oil
I’m looking for a little help. I changed my oil & filter and put in 4 qts like the owners manual said. Now I’m getting a high oil indicator on the electronic dipstick. Can anyone clarify the engine oil capacity for me please.
Old May 16, 2021 | 01:26 PM
decencyxdefied's Avatar
decencyxdefied
Check the oil per the manual on the dip stick not the indicator and drain some if needed. If you have the manual the capacity is in there
Old May 16, 2021 | 01:46 PM
Lunchbx13's Avatar
Lunchbx13
5th Gear
I have the owners manual. It said 4 qts. That’s what I put. The level on the dipstick is at the hot mark @ 200 degrees. Yet the led says high oil.
Old May 16, 2021 | 01:50 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
The dip stick does not have manual marks? You do not do oil changes by some god only knows electronic dip stick or the owners manual on amount. You put about 3/4 less then it says in book. Start it to fill filter. Turn it off an give it a couple three minutes to run down.
Now add to mid stick with bike in proper position for stick calibration.
On stand or level. Should be on stick.
Now drive it and get it HOT. Top off to full. Done that way, you will have reserve so you probably never add between changes. BUT CHECK IT. And done that way does not make it blow any more oil in filter box.
Old May 16, 2021 | 02:24 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
throw away the toy, put a real dipstick in it, check it every other fill up, problem solved
Oil hot, oil cold, oil upright, oil on side stand all read differently on a dipstick... your toy dipstick is not accounting for any of that
Old May 16, 2021 | 02:33 PM
harkon's Avatar
harkon
My Harley electronic dipstick always indicates higher on the LCD than the factory dipstick. Don't sweat it. If it's a bit high you'll notice the air cleaner gets really oily. I always run mine between 3 and 3.5 qts. I give the button a check every time I get gas, so that I know if it's getting low.
Old May 16, 2021 | 02:42 PM
TwiZted Biker's Avatar
TwiZted Biker
This I always top a twinkie at 3 1/2 qts and keep in mind there's always some left in the motor & oil circuit when you change it. Refill with 3 qts after a change, bring to temp check and top off as needed. This will also help over spray from the air cleaner and crank breather system.
Old May 16, 2021 | 05:28 PM
propflux01's Avatar
propflux01
Keep in mind, it is a dry sump system, so its not perfect in scavenging all the residual oil. Not to mention what is still in the lines, and oil cooler (if equipped). 3.5 Quarts, ride, check when warm.
Old May 16, 2021 | 06:20 PM
702's Avatar
702
You can count on that fancy dipstick being every bit as accurate as your fuel gauge.
Old May 16, 2021 | 06:37 PM
Lunchbx13's Avatar
Lunchbx13
5th Gear
I’m definitely not a fan of this dipstick. It does have manual marks. I don’t trust the lcd either that’s why I posted. Unfortunately this is what the bike came with. I have to get a factory dipstick. Thanks guys
