ABS Help !
Old May 17, 2021 | 07:31 AM
Nldp's Avatar
Nldp
6th Gear
Default ABS Help !
2014 street glide special . Dtc C1040 can anyone help diagnose. Clear code comes back without starting bike . Pump/motor are actuating. Solid abs light doesn’t go away or flash like it used to . Thanks
Old May 17, 2021 | 07:46 AM
Cobra1's Avatar
Cobra1
Have you removed wheels recently? Since the code comes on right away maybe a wire broken or plug bad for one of the wheel sensors.
Old May 17, 2021 | 08:48 AM
Nldp's Avatar
Nldp
6th Gear
All sensors read if unplugged and plugged back in . Throws codes when unplugged and are good when plugged in . I hear the abs motor cycle but code C1040 pops .
Old May 17, 2021 | 11:25 AM
Bingee's Avatar
Bingee
That code indicates a problem other than a wheel sensor. For some reason the pump is prompting the code. Could even be as simple as a weak battery. If not the system needs more thorough testing to diagnose.
oscarg
Jun 6, 2015 07:44 PM
bigirn
Apr 30, 2014 11:06 AM
1fathog
Wheels/Tires
Mar 14, 2013 10:42 AM
51Moe
Nov 14, 2010 10:39 PM
tuxster
Nov 29, 2008 09:31 PM
