Road king help
Old May 26, 2021 | 12:07 AM
Branden Matson's Avatar
Branden Matson
3rd Gear
Default Road king help
I have a 2000 road king that just doesn’t seem to want to idle one up to normal temp. I’m finding it very difficult to find replacement parts. Can anyone tell me if the idle issue is normal and what they had to do to correct this?
Old May 26, 2021 | 03:43 AM
eighteight's Avatar
eighteight
Carb or EFI ?????
Old May 27, 2021 | 07:15 PM
Branden Matson
3rd Gear
EFi injection
Old May 28, 2021 | 05:07 AM
eighteight's Avatar
eighteight
Don`t know squat about EFI
Others here do
Clean the IAC ?
Old May 28, 2021 | 05:51 AM
Hoginedgewood's Avatar
Hoginedgewood
Check engine light? Any codes?
Old May 28, 2021 | 07:52 AM
J F GO's Avatar
J F GO
Sounds like the air temp sensor needs to be replaced. No IAC on a 2000.
Old May 29, 2021 | 11:01 AM
Branden Matson
3rd Gear
No check engine lights no other issues. New fuel pump. But if I adjust the idle set screw then she backfires through intake.
Old May 29, 2021 | 11:06 AM
Stiggy's Avatar
Stiggy
Can you hold it at the correct rpm with the throttle?
Old May 29, 2021 | 12:55 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Originally Posted by Branden Matson
…doesn’t seem to want to idle one up to normal temp.
Could you better describe what it’s doing?
Normally, the idle is high when the engine is cold, slowing down to a normal idle as the engine is warmed up.
Old May 29, 2021 | 07:48 PM
Branden Matson
3rd Gear
bike idles fine when first starts up, then after engine is warm idle drops to the point it struggles to stay running and will stall out at stop lights. I can make it maintain idle with throttle.
