You could try removing and cleaning the vss on the tranny. Every Harley I’ve ever ridden ( more than a hundred) underread by 5%,
So now you know why so many vehicles want to run you over on your Slow Harley.
I fit a Healtech Speedohealer on my personal Bikes. Easy to fit and program @$ 80.
Can you remove the VSS without removing the starter? Maybe cutting down an Allen key to a lower profile
mine reads 5-7 mph off at 70. even still, i find myself passing more people than pass me when i'm doing +3 indicated over the speed limit. i go with the logic that my speedo is 'pretty close' and ride as if it is. i've found that in my older years, a couple mph is not gonna get you where you are going that much quicker. if you want to make a big impact on your time of arrival, you're gonna have to do substantially more than the speed limit. and that comes with all kinds of problems that i just don't want to deal with.
Different tires will make a difference in speedometer accuracy. My 2007 ran about 5 kph off until I changed the wore Dunlop to a new Michelin Commander II. With the new tire it was correct with my GPS
I’ve got to wonder…would wear of the tire….and perhaps brand of the tire… and perhaps inflation of the tire make a difference. It seems that all would have the possibility of changing the circumference some which would in turn change the reading of the speedometer.
