Squeaking/chirping/whistling noise
Old May 31, 2021 | 10:22 AM
RicManSr's Avatar
RicManSr
Default Squeaking/chirping/whistling noise
2014 Ultra stage 4, 40k on the clock.
I’m at a loss here. I’ve checked the exhaust brackets, and motor mounts. Can’t quite pinpoint the noise. Seems to be coming from the primary or top end. The noise raises and lowers with the throttle. No change if I pull in the clutch. Anyone have this issue before?
I don’t want to tear into things I don’t need to, but something is wrong here.
Old May 31, 2021 | 10:24 AM
RicManSr's Avatar
RicManSr
Trying to post the video
File Type: mov
Old May 31, 2021 | 10:28 AM
MURPHCC1's Avatar
MURPHCC1
Take off the air cleaner and see if you can hear it in the intake............Fuel injectors pulsing maybe
Old May 31, 2021 | 10:31 AM
pgreer's Avatar
pgreer
To me, it sounds like a lifter that won't pump up. Are they original lifters?
May need to raise the pushrod tubes and rotate the engine to get each lifter at the low spot on the cam and check for slack in the pushrods.
Paul
Old May 31, 2021 | 10:36 AM
brakeless's Avatar
brakeless
Check for rub marks in the pushrod tubes maybe?
Old May 31, 2021 | 10:54 AM
cwsharp's Avatar
cwsharp
Your description sounds like the squeak is timed with your wheel rotation nor your RPM's maybe? If so I found that to be caused by a defect in my drive belt... unless your throttle/squeak is when your bike is sitting still? Then a simple compression leak can cause a squeak...
Old May 31, 2021 | 10:59 AM
Sam2010's Avatar
Sam2010
I would also be looking at the belt.
I can't see the image or video posted.
Old May 31, 2021 | 12:10 PM
timbo141's Avatar
timbo141
Compensater bolt loose or warn comp, primary chain loose or bad adjuster?
Take outer primary cover off and have a look.
Headers on tight? Almost sounds like it could be an air leak exhaust or intake.
Good luck hope you find the issue and it is an easy fix.
Old May 31, 2021 | 01:22 PM
memphisharley's Avatar
memphisharley
sounds tinny like something loose and tapping against something.
Old Jun 1, 2021 | 08:20 AM
NiteOwl's Avatar
NiteOwl
Pull that primary cover, check the chain..
