Engine and transmission light
Old Jun 26, 2021 | 12:28 PM
David M. Rosinsky's Avatar
David M. Rosinsky
Stage III
Default Engine and transmission light
My 2006 Ultra Classic Electra Glide was not run for almost a year because of a disease I had. Now installed new battery and changed all the oils and oil filter. I start engine with no problem and will idle with no lights coming on. When I ride less than a mile engine and transmission lights come on, I stop and turn my ride off, a few seconds later I start back up and no lights, unless I ride it, which the lights come back on. Get home and look for a fault code and get P0562 battery voltage low fault code. Please can anyone help with this problem?
Old Jun 26, 2021 | 12:44 PM
EdwardK's Avatar
EdwardK
Do you have a multimeter to check charging voltage? You need to verify if it's charging, Should be around or over 13.5v when running.
Old Jun 26, 2021 | 12:55 PM
MURPHCC1's Avatar
MURPHCC1
Welcome aboard from Old Cape Cod!!!!
David, remove your address from your location, too revealing, Town and State are ok.....JMHU!!
Old Jun 26, 2021 | 02:44 PM
470004's Avatar
470004
Welcome from New York.
Old Jun 27, 2021 | 09:08 AM
David M. Rosinsky
Stage III
i will check that, thank you.
Old Jun 27, 2021 | 03:20 PM
dickey's Avatar
dickey
Never heard of a transmission light.
Old Jun 30, 2021 | 04:15 PM
David M. Rosinsky
Stage III
Checked battery while running engine two to three minutes and the multimeter was only at 11.8. Does this mean the voltage regulator is bad?
Old Jun 30, 2021 | 04:33 PM
MURPHCC1's Avatar
MURPHCC1
Again what transmission light????
The charging system doesn't kick in till about 2k rpms.
Bring it up to that and see what ya get.
https://www.hdforums.com/forum/elect...sting-1-a.html
Old Jun 30, 2021 | 06:49 PM
EdwardK's Avatar
EdwardK
Definitely charging system issues. 11.8 your just reading the battery voltage and it's not charging at all. Could be regulator or stator or both. There used to be a " sticky" at the top of the page on how to test both but I don't see it anymore. Use the search function here or google or you tube and you will find plenty of descriptions on how to test much better than I can describe.
In my limited experience, low voltage usually means the stator. If it was high voltage I would lean towards the regulator but I would find the charging system troubleshooting directions and follow them before throwing parts at it. I had a charging issue once and got very lucky and while testing, found that the voltage regulator had simply come unplugged. I hope you have similar luck.
Old Jul 17, 2021 | 11:50 AM
LazySundays's Avatar
LazySundays
Check this thread. He found that the wires from the bars to the neck had internal breaks causing an intermittent. It would explain all of your comm codes and probably the start switch code as well. Check really closely because the wire can be broken even though the insulation looks good. Sometimes you can feel a slight narrowing of the wire at the break point.
https://www.hdforums.com/forum/ignit...bcm-codes.html
Good luck and let us know what you find
