Primary vent effectiveness
Old Jul 19, 2021 | 02:09 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Old Jul 19, 2021 | 07:40 PM
JONNIEROCK's Avatar
JONNIEROCK
Originally Posted by murphspringer
Actually I did not join to rant. I did not join to have a bunch of condescending asshats apologize for the MOCO not doing the right thing when they had a known defect. This defect by the way is a safety issue should the transmission lock up when it goes dry on a long run.
As an engineer in the automotive industry for over 25 years I can assure you the are taking the cheap way out. If I could delete this account I would. I’m not seeking sycophants I’m seeking information on whether the bandaid works.
You have to be careful on here, a lot of people are butt hurt. Harley starting making this M8 4 years ago. You only have to ride one a couple of thousand miles to find out there's a problem here, (absolutely little to no R&D) and they still haven't corrected it, I know I've got a 2020 FLHTK. So we have two problems, a company who won't fix their bikes, and people who are to ashamed they got bit.
Old Jul 19, 2021 | 07:44 PM
smitty901's Avatar
smitty901
Granted they developed several attempts at correcting the problem with several bulletins. But their official line is still “in rare cases, caused by riding style”. Acknowledged would have been a recall with a proven fix.
I have worked for several automotive manufacturers and the bulletin and verbiage used is the legal department not acknowledging the problem to avoid a manufacturing change and recall.
Many of us owned the 2017 early bikes that were number 1 on the list and never had the issue. So it was not all bikes. The vent fixed the issue. Do not confuse the transfer issue with sumping to different issues.
Old Jul 19, 2021 | 08:00 PM
not a sock's Avatar
not a sock
...the best solution is;
buy a 2021 Touring Harley.
It will have a cable operated clutch and a vent hose installed.
You won't have to worry with Trans Oil Transfer.............
Old Jul 19, 2021 | 10:20 PM
Teknition's Avatar
Teknition
You should probably head over to the engineers forum and rant to them about how stupid they were to design something that transferred oil in the first place and let it out the door without sufficient testing?
Old Jul 20, 2021 | 01:47 AM
Dynamick's Avatar
Dynamick
Does anyone who had fluid transfer have results from the primary vent service bulletin? I have very high fluid transfer, 18oz in 4600 miles. Before I go through the work and expense of installing the kit I’m seeking real world experience since the moco doesn’t even want to acknowledge there’s a problem.
Sounds like you need to find a more honest dealership.
The head service writer at my dealership showed me the bulletin from Harley which tells them how to document fluid transfer, and the procedure for claiming reimbursement for performing the vent install at no charge to the owner, even if the bike is no longer under warranty. My '18 Street Glide is in the documentation phase right now, and I am confident of a satisfactory resolution to the problem.
Old Jul 20, 2021 | 05:19 AM
roussfam's Avatar
roussfam
Subscribed for entertainment potential, unless OP is a one and done.
Old Jul 20, 2021 | 06:16 AM
dajogejr's Avatar
dajogejr
Yep…slow news day…subscribed.
OP won’t be back.
It’s not a safety issue…I had the transfer, I’ve read nearly every post on the subject over time, I don’t recall ever seeing one instance of a trans locking up, not one.
Old Jul 20, 2021 | 06:48 AM
skratch's Avatar
skratch
or worrying about tuning it.....
Old Jul 22, 2021 | 12:34 PM
JONNIEROCK's Avatar
JONNIEROCK
Probably do like most, Put less amount in primary, keep adding oil to the transmission, and eventually after it transfers over to the primary you'll have the correct amount in each for about 200 miles.
