Check those tire pressures!
Old Aug 6, 2007 | 10:11 AM
beary's Avatar
beary
Default Check those tire pressures!
Hi All
I've had my RKC a few daysand noticed a front end whobble over 60mph. I wasn't sure if it was normal for this bike, so I didn't check it out, but it go so uncomfortable driving home last friday, I got off the highway half way home. I went to the forum to search the problem andread severalcauses. I decided to start with the easiest, the tire pressure. I nearly fell over when both tires read20psi. I had a long morning ride the next day, which gave me a chance to feel the bike withthe tires at 35psi. WHAT a difference. Now my RK is stable all the way up at least to 85mph. Solid as a rock. Now I'm checking the pressure everyday.
Beary
Old Aug 6, 2007 | 10:18 AM
Zimbob's Avatar
Zimbob
Default RE: Check those tire pressures!
Low tire pressure will get you everytime. I check mine before every ride.
Old Aug 6, 2007 | 10:21 AM
mrsr71's Avatar
mrsr71
Not intending to hijack this thread but, what tire pressures are you '07 SG owners using?
Old Aug 6, 2007 | 10:26 AM
flyslow's Avatar
flyslow
I have an Ultra and run 36 front and 40 rear with stock dunlops.
Old Aug 6, 2007 | 10:29 AM
lschultz's Avatar
lschultz
Yep ck them tires every day. You only got two so do it. It only takes a few minutes.
Old Aug 6, 2007 | 10:30 AM
oldhippie's Avatar
oldhippie
Thanks for the reminder.. I've got bad knees, so it's an easy thing to put off...getting down there and making the check/adjustments.. but it's important and well worth it in safety, handling and longevity of the tires.
Old Aug 6, 2007 | 10:35 AM
Zimbob's Avatar
Zimbob
usually run 40 front/rear.
Old Aug 6, 2007 | 10:41 AM
BlueDragon's Avatar
BlueDragon
I need to stay on top mine a lot better,as well~ Before a long ride this Saturday I checked them when topping off the tamk, and found both front and rear were down to 25psi! I kicked myself in the **** for not catching this sooner~ I'll be checkin 'em a lot more often now..
Old Aug 6, 2007 | 10:44 AM
gunrunner's Avatar
gunrunner
ORIGINAL: Zimbob
Why run 40 front? when max is rated at 36 on front, 40 on rear is only for fully loaded.
Old Aug 6, 2007 | 11:00 AM
04harleyboy's Avatar
04harleyboy
I run Metz and the front ~40psi, and the rear is at ~45psi (42-43 psi is recomended)
I don't trust my tire gauge 100%, in search of a better one.
