Need Lifter Education
Old Aug 2, 2021 | 08:56 AM
Erilflynn's Avatar
Erilflynn
Default Need Lifter Education
So I’m starting to hear a little “clatter” on startups in the morning. Have about 30K on my ‘19 Stage 1 (all Harley)RG After the bike warms up it seems to go away.. I’ve read some similar posts and lifters come up often. Don’t know how concerned I should be. Can someone educate me. TIA
Old Aug 2, 2021 | 11:56 AM
hattitude's Avatar
hattitude
The early twin cam lifters, were considered to be excellent lifters. In June of 2011, HD changed to the #18538-99C lifter.. commonly referred to as the "C" lifter. They are considered to be a weak spot (some would use stronger words) in the valve train.
Per the online parts finders, your 2019 M8 uses the "C" lifters.
Barring a lifter problem, I wouldn't open a cam chest just to replace the "C" lifters, but anytime I open a cam chest on a new-to-me bike that has the "C" lifters, they are replaced.
I prefer the Johnson Hylift from WFO Larry (Larry's motorcycle & Machine). I understand he may have trouble getting some products due to Covid supply issues... http://www.larrysmotorcyclemachine.com/lifters.html. of course there are other good lifters. I've never heard a bad thing about an S&S lifter, but they can be pricey..
Your issue could be several things. I don't own, nor have I worked on an M8 engine. I have read an issue with the rocker arms and an adjustment procedure.. so your noise could be a rocker adjustment issue.
However, if you open the cam chest for an inspection, or remove the pushrods for any reason, IMHO.... I would get new lifters...
Old Aug 2, 2021 | 01:24 PM
Erilflynn's Avatar
Erilflynn
Thank You
Old Aug 2, 2021 | 01:55 PM
lp's Avatar
lp
Mine were the same way after about the same miles. Funny thing is that since new, the noise would come and go, but around 30K it stayed.
Was never worried though. Almost expected given all the reports on noise these OEM lifters can make after a spell.
Replaced mine when doing a cam job with Woods directionals. No more noise.
Old Aug 3, 2021 | 10:33 AM
nordhaven's Avatar
nordhaven
My 2019 FLHTK is the same. Just started at approx 32,000 K
Old Aug 3, 2021 | 01:10 PM
journeyman's Avatar
journeyman
No doubt you need new lifters.
If you've never done it before, it's a good idea to add a set of adjustable push-rods vs taking off the top end.
Here's a video -
Drodrigueznyc
Milwaukee Eight (M8)
30
Mar 1, 2017 07:39 PM
easyrdr
Aug 29, 2013 07:29 AM
Zac Strayer
Feb 28, 2011 09:25 PM
2008FLHP
Dec 15, 2008 06:43 PM
