The first link will allow just a sissy bar but if you want both the second link will be required as well
WP
I have the front docking brackets but with the sissy bar I got you have to have somewhere to mount the back of the sissy bar which is quick detach also. So I need brackets for the back also
Read the instructions for each kit. For the sissy bar only docking kit the front points are mounted at the shocks and the rear points are on the bracket. For the tour pak you would need the rear docking kit in addition which have the loop plates.
I read the directions several times and couldn't figure it out. I have the directions from hogworkz not Harley, I'm not sure if they are different or not but the ones I have are like trying put together a puzzle with one eye in the dark 😁. But when you mentioned something about the front mount being by the shock,something clicked and I had to go out last night at 11p and look at it. I finally got it on and looks good. Thanks for everyone's help. Greatly appreciated
