4 Hours for Dyno?
Old Aug 7, 2007 | 12:36 PM
GasCan's Avatar
GasCan
Default RE: 4 Hours for Dyno?
Dyno sessions (costs and time slots) can vary by dealer, and also by what is being done. For new setups with mapping and tuning 4 hours is pretty standard as they allow a half day for bike setup, mapping, minor tuning, and performing what is usually 3-4 pulls after everything is setup. If you already have your bike setup when you take it in, some dealers will charge a flat rate of 1 hour for 3 dynopulls. Large inch performance builds can often charge a full daywith rates varying between 500.00 and 750.00 per day but includes extensive tuning which can sometimes take more time than allotted.
Sound like you dealer is on par. Just make sure you're happy with the tune after and that it doesn't pop and fart.
Old Aug 7, 2007 | 03:50 PM
ScooterJammer's Avatar
ScooterJammer
bdavis...It tookBrian at Scooters Performance2-full hours to Dyno my '04 Road King, you can see my set up by my signature. It included rolling the bike into the Dyno area, loading it on the machine, tying it down and adjusting the safety devices on the Dyno, attaching the various monitoring and data cables, Air/Fuel sensor, etc. Then, there's the actual set-up of the computer, loading your bikes individual data, e.g., pipes, a/c, cams, headwork, and so on. After all of this is done the Dyno Tech performs his baseline run to establish were you are right now. After all of that, at least in my case, he did three (3) power runs, tweeking as he goes along. After it was all said and done, I was looking at 88.5 lbs TQ @ 4050 rpm (original 77 lbs TQ) and 77.4 peak HP (original 69.8 HP). I don't think 2 - 3 hours is out of line, however, I do think 4-hours is a problem. Either you've got a very exotic set-up or the Tech doesn't know what he's doing. To me,a flat rate for a custom Dyno tune might be the best way to go as long as you trust the guys doing the work.
PhilM's Avatar
PhilM
It really depends on how good ya want it to be...
The "best" results take more time, particularlly with SERT tuning. Even 10 hrs is not unreasonable.
Old Aug 7, 2007 | 04:00 PM
otterbob's Avatar
otterbob
It all depends on the proficiency of the guy doin the dyno. How fast he can change the numbers accuratley and how good he is at keeping the throttle at the desired throttle position.
Old Aug 7, 2007 | 04:16 PM
BrianDamage's Avatar
BrianDamage
local dealer here has $850 listed as the price for a dyno -tune [:@]
Old Aug 7, 2007 | 09:48 PM
choochoo's Avatar
choochoo
I'm finding a lot of dealers (in my area)are doing a flat rate based on 3 hr for the first dyno tune.
After that it's a little less as they only need to tweak future changes.
Old Aug 8, 2007 | 03:58 AM
PapaTravis's Avatar
PapaTravis
Here's a question. I have a '05 rk custom with a carb. The carb was rejetted when I added the pipes and AC. Would a dyno benefit someone with a carb, or is it just done to see the numbers? What does a dyno do, if you have a carb?
Old Aug 8, 2007 | 04:31 AM
Abnmarine's Avatar
Abnmarine
It sounds about right if the tune is worth a crap.
I used to build supercharged Mustangs to race and had one dyno tuned. I drove 6 hours to meet the tuner who was in town just for tuning that week. He spent 20 minutes on the car and was finished. It made 520 rwhp / 544 rwtq. I heard he was one of the best and believed it afterwards. He used to work for Ford and help designed the ECU for the Mustangs/
Old Aug 8, 2007 | 05:51 AM
relli's Avatar
relli
new to this . how often should you have to have a dyno done?
Old Aug 8, 2007 | 06:34 AM
bdavis's Avatar
bdavis
Thanks for all your insight everyone. It has been very helpful.
Mr. Wizard
Aug 31, 2016 08:19 AM
rockajet1
Jul 5, 2014 05:45 PM
HDCrossbones09
Jan 5, 2012 05:22 PM
shrini23
Oct 4, 2009 12:01 AM
AceHog
Oct 10, 2006 08:19 AM
