2009 Ultra Barley running..
Old Aug 31, 2021 | 04:43 PM
Stratattack's Avatar
Stratattack
Default 2009 Ultra Barley running..
The forum looks different from last visit, I don't know if
I'm posting this in the right spot, I can't find; ''troubleshooting or diagnostics''
Yesterday when I was out and about, my keyfob wasn't recognized,
the flashers went back and forth, only the headlight and running
lights worked, nothing else. I replaced the keyfob battery still nothing,
disconnected and reconnected the ecu, then it recognized keyfob and
started.
It sounded fine but ran rough on acceleration, like 1/2 power, eventually ran fine.
Today I went to start it, and it started but ran really rough and shut back
down.
Changed spark plugs, checked plug wires (visual inspection) look new.
It coughs and sputters, then pull throttle and it will sput and quit.
It was too hot when I started trouble shooting, to go very long will
get back at it in the morning, but I wonder if this is some weird coincidence
that the keyfob was not recognized, and suddenly it starts running
terrible or... it always has run great , with exception of a fuel line failure,
whereby it didn't run at all.
Just throwing this out now, maybe someone has some ideas. :shrugs:
Thanks.
Old Aug 31, 2021 | 04:47 PM
kel03's Avatar
kel03
Make sure your battery connections are snug and tight, that's the first thing to check.
Old Aug 31, 2021 | 05:06 PM
MyFavRk's Avatar
MyFavRk
Start by having the battery load tested , most places will do it for free , sounds like it's getting tired .
Old Aug 31, 2021 | 05:45 PM
Stratattack
Thanks, yeah, 5 mo old battery 600 cca, cranks like a raped ape.
Old Aug 31, 2021 | 06:16 PM
MyFavRk's Avatar
MyFavRk
Could be a plugged fuel filter , if you end up going into the tank , I would change out the fuel hose and pressure regulator as well , especially if your bike is a keeper . The fuel filter should be changed at 25k , and the hose is usually on it's way out at that time too .
The best way of knowing if you have a fuel issue , is by doing a pressure test , but if that's not possible , depending on the miles you have , I would do it anyway .
Old Aug 31, 2021 | 06:26 PM
Stratattack
Thanks man, great looking bike!
Yeah, that pressure test is coming up in the am, I bought
one when the bike quit running a few months ago. New everything in-tank,
but will pressure test anyway. Have some choke intake (crc) coming
next week, I kinda don't think that will be the issue, but seems like
a good maintenance thing, something I stumbled on while searching today.
Old Aug 31, 2021 | 07:36 PM
Firedude2's Avatar
Firedude2
Any chance of bad fuel? Water and or just bad from age can cause these symptoms.
Old Aug 31, 2021 | 07:51 PM
MyFavRk's Avatar
MyFavRk
Great , I've heard of fuel filter housing coming loose or hose letting go , could be an o-ring in the quick release being fudged inside and not letting it completely set in place .
Curious to know what you find , keep us posted , good luck !
Agree with firedude , try running some seafoam , 1 ounce / gal . It shouldn't take to long to clear things up , it that is the case .
Old Sep 1, 2021 | 05:15 PM
memphisharley's Avatar
memphisharley
bike should be throwing a code with these symptoms.
Old Sep 1, 2021 | 09:00 PM
Highclasshobo's Avatar
Highclasshobo
"disconnected and reconnected the ecu, then it recognized keyfob andstarted"
Maybe your ECU is on the fritz or has some corrosion on the connectors. That could be the cause of the rough running of the engine. Something to look at anyway... Do a search here on the forum there seems to be something with the 2008-09 years ECMs being replaced.
