Headlight lens
Old Sep 1, 2021 | 08:18 AM
Wizard46's Avatar
Wizard46
Question Headlight lens
2002 EG Classic
My headlight lens is a little cloudy. I bought a 3M headlight restoration kit and reading the instructions it states not to use on glass. I think my lens is plastic as most newer autos but can't tell for sure.
Anyone know what it is made from.
Old Sep 1, 2021 | 08:27 AM
dawg's Avatar
dawg
Any thought to upgrading to an LED like the reasonably priced Sunpie units?
Old Sep 1, 2021 | 08:36 AM
NoRegerts's Avatar
NoRegerts
I always thought the lenses were glass. Try tapping on it gently with a metallic object. If it "tinks", it's glass.
It's not me, but if it were, I'd simply replace it with an LED model and be done with it. Headlights are a safety item and should be working as well as they possibly can.
Old Sep 1, 2021 | 08:38 AM
Uncle Larry's Avatar
Uncle Larry
They usually cloud up on the inside ... Several threads on this topic ... Remove and clean with a solution and dry ... Good luck
Old Sep 1, 2021 | 08:43 AM
Uncle Peepers's Avatar
Uncle Peepers
I think.
That lens is glass. The 3M restoratrion kit won't hurt it. It just won't work.
Old Sep 1, 2021 | 09:34 AM
HD Bobber's Avatar
HD Bobber
Originally Posted by Uncle Peepers
I think.
yes that. I would just replace it. MANY options out there.
Old Sep 1, 2021 | 12:01 PM
NODYNA's Avatar
NODYNA
Easy fix for clouded lens, remove headlight, remove bulb, pour alcohol, not JD, swish around, use soft material moved around the lens to dry with the eraser end of a pencil, reassemble.
Old Sep 1, 2021 | 12:06 PM
Mr.Lee's Avatar
Mr.Lee
My 2003 RK is a little cloudy too. Good tip to remove and clean the inside with alcohol. Hope it's as easy as it sounds.
Old Sep 1, 2021 | 12:34 PM
b0fh's Avatar
b0fh
yup, as said the fog is inside. I used to clean mine with some raw rice and detergent. just pour those inide plus water, slosh the hell of it around then drain and rinse - looked brand new afterwards, at least for 1-2 years
then i just moved to LEDs like everyone else. much better light.
Old Sep 1, 2021 | 12:39 PM
Taxgod4u's Avatar
Taxgod4u
Can also use Ice if no rice on hand.
