07 RG WOBBLES
Old Aug 9, 2007 | 09:14 AM
NICK56's Avatar
NICK56
Default 07 RG WOBBLES
Has anyone had any luck getting rid of the high speed wobble on this bike?
Old Aug 9, 2007 | 09:20 AM
SIM's Avatar
SIM
Default RE: 07 RG WOBBLES
what speed range are you talking. Yellow Power Ranger speeds or 75-85 mph? Off the top of my head I would say check you tire air pressures. I don't have any wobbles except in the 325-350 mph range.
Old Aug 9, 2007 | 09:26 AM
Biggzed's Avatar
Biggzed
I haven't experienced any wobbles on mine. How high of a speed are you talking about? I ran pretty much all day between 75 - 85mph on my way home from Hollister in July and never felt even a bobble. Have you checked your tire pressure and tire condition, shocks have some air in them, everything tight like it should be?
Old Aug 9, 2007 | 09:33 AM
The Vig's Avatar
The Vig
No Wobbles here either. I cruise consistanly between 65-80 on the highway here in Chicago (crappiest raods in the world) and havent had any experience like that.
Old Aug 9, 2007 | 09:43 AM
Blackisfast's Avatar
Blackisfast
No wobbles...check your stuff.
Old Aug 9, 2007 | 04:49 PM
Kahuna's Avatar
Kahuna
No wobbles here either. Mine is an '05 RG with factory spoke wheels. Sounds to me like air pressure or spoke wheel (if you have them) issue.
Old Aug 9, 2007 | 05:23 PM
mysticwolf's Avatar
mysticwolf
Nope, none, nadda on my 06 ran mine about 85 mph. diddo on the air pres.
Old Aug 9, 2007 | 05:26 PM
pittguy's Avatar
pittguy
1wrong tire pressure[/align]2 worn out tires[/align]3wheel not ballanced[/align]4 vehicle not in alignment[/align]5fall away out of spec[/align]6wrong swing arm torque [/align]7 wheels not true[/align]8 loose spokes[/align]9 defective tire[/align]10 bad wheel bearing[/align]11 bad swing arm bearing[/align]12 weight load beyond the gvwr spec[/align]13 bad neck bearings[/align]14 replacement tires with a low load rating[/align]My first guess is a tire change will correct this[/align]
Old Aug 9, 2007 | 07:26 PM
PhilM's Avatar
PhilM
Pittguy has posted a nice list of potential causes.....
I've had 2 RG's (02 & 05) and have close to 70k miles on them combines and never had any "wobble issues..... There are plenty of times they've run over 100mph... no issues....
Old Aug 9, 2007 | 07:29 PM
gilbos440rt's Avatar
gilbos440rt
No wobbles here 80 to 110 flies true, fast sweepers with rain groovescould use a little work, can you say STR8
