Glad the cause was found. yes it's not a dragster, so even withh bigger HP the tire shouldn't distort that much. Better tire and double check loaded sag before you head out again.
So you think even contacting that bracket wouldn't have done that to another brand tire? Hard to say I would think.
My thoughts too. You said earlier you had at least 1/2" gap. If that tire moved that much, I'd s**t can it anyway. It's not rated for what you're doing with it and consider yourself lucky it happened now and not on the road. Now, go buy a real tire.
Thanks. Yeah expensive mistake and it still boggles my mind since I've been running that bracket no issues. I might end up switching to the oem style more square looking one. By the time it's back together and off this guys lift it's gonna be to cold to tune so I'm ****ed.
Better that you find the issue while on the dyno as opposed to heading out on a long trip.
As a general rule, I try to avoid purchasing anything made in China, especially tires. I simply don't trust anything made in China to meet the most basic standards of quality and especially don't trust them when it comes to products that could directly impact my safety. I realize that the tire was not at fault in this case, but I still wouldn't run any tire made in China period.
Sounds like you've had a run of bad luck and are due for some good luck! Hopefully you get things sorted and get back on the road soon.
Yeah I hear ya and thanku. Unfortunately I'm sure there are many components on Harley's made in Japan and China lol
I purchased my replacement bike last fall from a dealer. Tires looked to be newer But I don't know if the previous owner put them on or if the dealer did or how many miles they had. They were shrinko. They were ****. I easily get 20k from Dunlap tires I'm old and slow. Less than 5k on them and they were wore out.
Yes my injection has made in china all over it. Love the racism Shinko are a japanese company. They have a couple of plants in the US ok electrical not tyre! Calling south korea chinese is akin to calling canadians yanks they go off!
I only buy Dunlops, but your damage is probably due to faulty rebuild. Something is probably rubbing against that tire. And that will probably be even worse with you on the bike. You shouldnt ride until you figure it out.
If the bike was strapped too tightly down for the dyno (perhaps under inflated a bit) the tire may have "unloaded" or rebounded the flat spot resulting in a tall budge in the prefect place and timing to smack that bracket. Might not be totally the tires fault, but probably is since it may not have held it shape to spec.
I posted that the rear bracket was the culprit. What do you mean faulty rebuild? I put the bike back together lol.
Is a 1/2 inch really enough clearance for the rear bracket? The stock oem fender bracket definitely allows more room for the tire. I had my suspicions as I was driving to pick the wheel up that the bracket caused this. I'm even wondering if the old bracket even slowly rubbed away at the original tire. Might just be an error on my part.
