Metals used on 2014+ Harleys
Old Dec 20, 2021 | 08:25 AM
xpesrx's Avatar
xpesrx
Question Metals used on 2014+ Harleys
I am preparing to do some electroplating and powdercoating for my bike and I'm being asked a question I don't know the answer to. What types of metals are used?
I've done some internet research but don't want to guess and tell them wrong. By looking it's hard for me to tell chrome vs polish aluminum vs polished stainless steel; billet aluminum vs steel, etc. And then there is the questions of is the steel zinc plated or is the chrome plating on steel or something else?
Can anyone tell me what these parts are made of or plated with on a 2014+ Road King or point me in the right direction as to where I can find out:
  • Rocker boxes
  • Bolts and Nuts
  • Timer cover
  • Derby cover
  • Jiffy Stand
  • Crash bars
  • Saddlebag guard bars
  • Tank badges
  • Fender script badges
  • Fender trim
  • Footboard pans
  • Headlight surrounds
  • Turn signal surrounds
  • Taillight surrounds
  • Pushrod coverings
  • Fog light bar
  • handlebar cover
  • saddlebag latches
  • vance and hines pipes
My bike is not blacked out or anything, it's standard issue. ( https://www.motorcycle.com/specs/har...-reg/base.html )
Old Dec 20, 2021 | 08:38 AM
NoRegerts's Avatar
NoRegerts
  • Rocker boxes - chrome plated cast aluminum
  • Bolts and Nuts - zinc plated steel
  • Timer cover - chrome plated cast aluminum
  • Derby cover - chrome plated cast aluminum
  • Jiffy Stand - chrome plated steel
  • Crash bars - chrome plated steel
  • Saddlebag guard bars - chrome plated steel
  • Tank badges - sheet aluminum stamped out or plastic
  • Fender script badges - sheet aluminum stamped out or plastic
  • Fender trim
  • Footboard pans - chrome plated steel
  • Headlight surrounds - chrome plated steel
  • Turn signal surrounds - chrome plated cast aluminum
  • Taillight surrounds - chrome plated cast aluminum
  • Pushrod coverings - chrome plated steel
  • Fog light bar - chrome plated steel
  • handlebar cover - chrome plated cast aluminum
  • saddlebag latches - chrome plated steel
  • vance and hines pipes - chrome plated steel
Does this look about right?
Old Dec 20, 2021 | 09:23 AM
jake24lt's Avatar
jake24lt
  • Rocker boxes= aluminum,with or without plating, paint or powedercoat some are natural, or with clear coating
  • Bolts and Nuts=usually, zinc plated steel
  • Timer cover= aluminum,with or without plating paint or powedercoat some are natural, or with clear coating
  • Derby cover=aluminum,with or without plating,paint or powedercoat some are natural, or with clear coating
  • Jiffy Stand= steel
  • Crash bars= steel
  • Saddlebag guard bars= steel
  • Tank badges =depends, some are aluminum others may be pot metal
  • Fender script badges=depends, some are aluminum others may be pot metal
  • Fender trim ???
  • Footboard pans= steel
  • Headlight surrounds= some are aluminum others are steel (Think fat boy or touring bezel ring)
  • Turn signal surrounds=aluminum
  • Taillight surrounds=aluminum
  • Pushrod coverings=steel
  • Fog light bar=steel
  • handlebar cover= ( handle bar clamp) aluminum
  • saddlebag latches=aluminum
  • vance and hines pipes=steel
These are based on handling these parts and doing some powder-coating myself. Although I have been wrong before.
Old Dec 21, 2021 | 06:23 AM
davekp's Avatar
davekp
You can separate steel vs aluminum or zinc die cast with a magnet.
Old Dec 21, 2021 | 08:52 AM
chopper_man's Avatar
chopper_man
If your powder coating guy is not familiar already with motorcycle parts it's time to find another vendor! You need one who specializes in bike parts. Way too many surfaces, ports, passages that need to be protected from the coatings/platings.
Old Dec 21, 2021 | 09:28 AM
NoRegerts's Avatar
NoRegerts
You're absolutely right, but the electroplating process varies greatly from powder coating. But, something I'd not considered. Those really are questions one should not need to ask if they do this type of work.
Old Dec 21, 2021 | 11:06 AM
xpesrx's Avatar
xpesrx
These questions are from the powdercoat manufacturer itself. They are doing a color match to ensure I get the correct color no matter what type of metal it is applied to. They will let me know which powders and procedures will be able to match all metals to the same color, tint, shine, etc.
Vipers Harley
Stock Harley Take Offs
Mar 28, 2021 10:46 PM
berniemc
Touring Parts
Sep 4, 2017 10:32 AM
JCFLHRS07
May 18, 2008 04:35 PM
OneBlackFly
Detailing
Dec 6, 2007 07:52 PM
clap
May 10, 2006 02:00 AM
