chrome accents
Old Dec 30, 2021 | 11:08 PM
O.T.'s Avatar
O.T.
Stage III
Default chrome accents
hello all, new to forum. installed aftermarket chrome trans cover on 04 flht. now bike shows neutral when in 5th gear. loosened cover and tried shifting it around, also removed neutral switch and reinstalled not as tight. no change. considering adding a washer to shim to see if it helps. any seasoned riders got ideas? thanks. be safe.
Old Dec 31, 2021 | 05:42 AM
kojak's Avatar
kojak
Put your stock cover back on and see if the problem goes away. Basically, your neutral switch is behaving badly because it’s not lining up correctly with the detent on the tunnel. Could be the aftermarket cover is not lined up correctly before tightening or it’s wrong for your model year bike. Before you torque it down, install and connect the switch and shift through the gears and see if the light comes on in any gear except neutral. If so, try shifting the cover a bit to square it off and check again. If that doesn’t solve the problem, replace the switch. The switch comes with an oring for your bike I think, I wouldn’t be adding washers to make it work, just my 2 cents.
Old Dec 31, 2021 | 05:01 PM
O.T.'s Avatar
O.T.
Stage III
i will do that. thanks Kojak
O.T.
Welcome Area Only
17
Jan 29, 2022 11:15 AM
SmokeyJoe101
Touring Parts
Apr 14, 2018 06:55 PM
marcocast
Jun 4, 2015 09:42 PM
davidw221
Jan 11, 2014 02:01 PM
DonJulio103
Jun 8, 2012 04:17 AM
