Feeling out a 2004 FLHTPI
Old Jan 7, 2022 | 01:39 PM
  #31
skyhawk940's Avatar
skyhawk940
I had an 01 police bike and loved it. It got totaled. The best thing about the police bikes is the saddle bags. I love the way they latch and open. I have an 03 Electra now and I think the latching system on them is stupid compaired to the police bags. If you were to put a tour pack on it, you need to raise it 3/4 inch higher with spacers to clear the bag lids.
Old Jan 7, 2022 | 04:19 PM
  #32
dawg's Avatar
dawg
Originally Posted by brakeless
dawg, for $75 you can replace the outer cam bearings too. Curious why you didn't recommend that to OP also. Maybe different lifetime? At that mileage, I would.
True, I took that as a given when pulling the cams to replace the tensioners.
Old Jan 8, 2022 | 10:36 AM
  #33
bigskyroadglide's Avatar
bigskyroadglide
My 04 police bike, has a lot of miles on it. Approaching 200k. The engine has been built 4 times, with the cases split once. First build was cams, gear drive, jugs(95 kit), pistons and heads, second was welded crank, Timken and hotter cams, rings, third was forged pistons with 107 kit and heads, last was rings, cam plate, cams, springs and larger valves.
The twin cam will hold up and is easily rebuilable. I've busted the case on one with a lifter issue, broken valve springs and had a crank shift.. not much that cannot be fixed, just takes money time and planning.
I would not be scared of an 04 with 42k. The bike has not really been ridden.. my 04 is right at 200k, my 10 is at 48k, and my 12 CVO is at 22k. All 3 are twin cams. All have had engine work. Buy it and ride it. When it breaks, fix it.
Old Jan 8, 2022 | 11:04 AM
  #34
rigidthumper's Avatar
rigidthumper
From Harley
1) 24017-10 $20 Inner cam bearings ( the good ones)
1) 39954-99A $60 Outer cam chain tensioner
1) 39964-99A $60 Inner cam chain tensioner
1) 17045-99D $100 Cam service kit (all needed orings, bearings, gaskets, breathers)
From aftermarket
1) 2313 lifters $150
1) TW21 cams $ 300
Total parts (I would spend a little more and get fresh fluids/filters @ the same time) is around ~$700, plus tax and labor.
Old Jan 8, 2022 | 11:05 AM
  #35
brakeless's Avatar
brakeless
I appreciate what you're saying and I agree with the old adage "nothing is impossible, just costs a lot". But the "Ride it. When it breaks, fix it." Isn't sitting real good with me as advice to new HD owners. I kinda get what your trying to say, but It's really all about proper maintenance. And then of course, lets leave out beating them to the breaking point out of this conversation. If someone intentionally beats their bike they have to believe something's going to break. Proper maintenance and normal riding these Twin Cams are fine. With a stock early year Twin Cam proper maintenance has to be understood that one area must include checking those cam tensioner shoes every 10k miles. It's not that big of a deal. And neither is opening the oil filter and looking at what's trapped in the media. See plastic, or metal and you should stop riding it until you find and fix the problem. Not just keep riding it until it breaks because that could be a blown engine.
Old Jan 8, 2022 | 11:11 AM
  #36
brakeless's Avatar
brakeless
Originally Posted by rigidthumper
From Harley
From aftermarket
1) TW21 cams $ 300
I like it. But for me it's $65 for the shoes, pins, gasket, and anvil for installing the shoes from Cycogaskets.com
Old Jan 8, 2022 | 01:11 PM
  #37
bigskyroadglide
I don't disagree and if you check the mileage I listed you can't make that without proper maintenance, I went gear drive to eliminate the cam tensioner issue. The reminder of my build issues were not maintenance related but performance related. 90% of people will not experience ever taking a twin cam apart if they ride like most Harley riders. The bike in question is a typical example. Avg mileage is 2500 to 3 k per year. So routine maintenance is not even routine, it's more like annual.
I've ridden that average miles in 3 days, so I expect the more you ride and the higher the sustained miles, the more you will spend on the engine and the likelihood of a problem developing is increased. That's simple math and is applicable to any mechanical device. Maintenance will not eliminate that it just delays the need.
I'm not saying ignore the problem, I'm saying chances are given higher mileage the problems will become more apparent. Fix em proactivly or don't, either way your going to spend the $$. One way you control the other you don't. And the one you don't conttrol could be more catastrophic.
Old Jan 8, 2022 | 01:22 PM
  #38
Chad1200's Avatar
Chad1200
Nice bike. If I was going to buy this bike and keep it, I would spend the money to upgrade the cam chest internals properly. Peace of mind is worth it to me.
Old Jan 8, 2022 | 01:55 PM
  #39
brakeless's Avatar
brakeless
Nice clarification. There's a whole bunch of new owners out there that will never change their own oil, let alone pull a motor and split the case. My hat's off to you for the ability to do that. "Maintenance" is an procedure that can viewed several ways as far as I'm concerned and I was just pointing out my version goes a little beyond most. Totally agree with you though on your points.
Old Jan 8, 2022 | 08:14 PM
  #40
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I’ve an 04 RK myself, with 60k miles on it.
I went the shoes only route some years ago. At the time, it was the most economical route. Today, I’d go gear cams, but that’s a personal choice.
The outer tensioner will get minimal wear, as it’s trailing the chain. The inner tensioner is opposite, leading the chain, so it gets much more wear.
Another weak area is the inner cam bearing. It’s pretty easy to do, as long as you’re in there. Mine had a touch of galling, so I replaced that camshaft.
Mine has been basically flawless in the 6-8 years I’ve owned it. It’s huge, it’s heavy, and it’s delightful in its own way.
