2003 Road King
Old Feb 2, 2022 | 03:54 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
More than up, I want them to come back further, and be a bit narrower.
Picked up some pairs of cheap bars to experiment with at a swap meet the other day.
Old Feb 2, 2022 | 04:14 PM
BackRoader's Avatar
BackRoader
Good advice here. I went with 10 inchers, and then a couple years later went higher. Cost me double because I did not want to change cables, etc. Dont make the mistake I did.
Old Feb 5, 2022 | 08:10 AM
btsom's Avatar
btsom
I have an 08 Road king and I believe your machine has the same frame. I asked the same question to the parts guy at the local dealer and he recommended the "Heritage Style" handle bars.that would work with the stock cables. I am also 5'-11" with a 32 inch sleeve length and those bars have worked well for me. I have them leaned back so they just barely clear the tank in full locked turns. When looking at pictures of the late model Kings, the factory bars on those bikes appear to put the grips in the same place mine are now. You might want to sit on a new machine to judge how well those bars would suit you. It has been a long time since the bar change. I don't specifically remember if a throttle by wire extension cord was needed, but I don't believe I needed one.
Old Sep 26, 2023 | 06:26 PM
jakebrake1968's Avatar
jakebrake1968
1st Gear
Originally Posted by predatornut
I installed 12’s on my Electra glide. I bought the LA Choppers clutch cable and throttle cables and they were all too long so I am in the process of replacing them. It looks like +4-+6 on the clutch and +4 on the throttle/idle will fit nicely with stock routing. The wiring fit without any issues, no extensions needed.
I must be the exception because I got 12’s and think I would have been happier with 10’s. It seems like my hands are a little too high so I have to drop them to get the blood flow back after a while. Otherwise they are very comfortable and look good. I’m 5’8”.
you want to sell those 12's?
Tkelley1963
Feb 7, 2021 08:18 AM
MidwesternMatt
Touring Parts
Aug 26, 2019 03:48 PM
flhchaz
Jul 27, 2019 10:43 AM
JDJ66
Mar 16, 2014 09:10 AM
cbrunson
Oct 28, 2005 07:07 PM
