Which air cleaner for 07' with Rinehart Slip-ons
I'm going to put some Rinehart Slip-ons under my 07 street glide. Now I am wondering which air cleaner I shall use. I don't care about the football cover.
In your opinion which air cleaner should I use, the SE, K&N or the Ness Big Sucker?
I run the SE with a K&N filter. The filter that comes with the SE is junk. What I did is bought all of the parts for the SE kit seperately minus the filter and then bought the K&N filter. It was cheaper than the SE kit, K&N kit or BS. I personally don't like the BS because the breather bolts are a PITA to tighten down and the backplates have been known to crack where the breather bolts go in. I had two crack on me on the BS I had on my Sporty.
I put the SE setup on mine but Im going to replace the filter with a K&N. The rubber seal came apart on the filter. Btw I replace the cover with a HD round cover. I didnt care for the football look either
Ness Big Sucker.... Recommend getting it with the Chrome Backing Place in case you ever want to change the Football air cleaner cover..
relli... Yes you do with the A\F change
