Can anyone tell me what the advantages are for switching from my Screaming Eagle air cleaner to a K&N? Is there really going to be more airflow/hp gain or are they really close already? I know the filter element will last longer, I'm just wondering about power. I'm running a PC III so I may need to re-map also?
Sweet Standard bro. I'm not an expert in this area, but I know K&N makes quality filters. Is the quality, performance, value different enough from the screamin eagle, I doubt it. I have the ness big sucker, and when the filter itself is done, I will likely replace it with a K&N, but not the whole breather.
I don't believe there is much difference between K&N and the SE. I have the K&N 3909 kit and am happy with it but if I already had the SE air filter setup I don't think I would spend the money to switch.
From: CHILLIWACK B.C CANADA: have a u.s shipping adress
the se filter housing is a much sturdier cast piece than the tin k+n ..best case scenario is a s.e kit with the repacement k+n element
The dealer did the Screaming Eagle install ( I bought the bike used) and there is no backing plate on the bike. I assume if I need to change the filter element I could go with the K&N and leave everything as is. No re-map and no reason to add a backing plate?
K and n is far better. It used to be that the s/e filters element would fall apart and get sucked into the engine. I do not know what they are like now as I have the k and n.
