LED Bulbs for directionals
Old Feb 11, 2022 | 08:03 PM
SoCalHarley's Avatar
SoCalHarley
Originally Posted by scott_0
mine are Amazon cheapies, but they have been awesome!
Can you post a link for them. Thanks
Old Feb 11, 2022 | 10:22 PM
Traildale's Avatar
Traildale
Amazon Amazon
Amazon Amazon
1156 front
1157 rear
Old Feb 12, 2022 | 07:53 AM
RKZen's Avatar
RKZen
Originally Posted by SoCalHarley
I was in Carlsbad area about 45 min north of San Diego for 25 years but moved to Savannah last year. Custom Dynamics makes nice stuff but really looking to do a simple bulb swap.
Familiar with Carlsbad. I have friends in Del Mar. Grew up north of LA area about 40 years, but moved a state north of you.
Good luck in your search, but don't discount CD. Lifetime warranty.
Old Feb 12, 2022 | 07:59 PM
SoCalHarley
Thanks bought them today.
Old Feb 14, 2022 | 09:33 AM
SoCalHarley
I installed them but I have the hyperflash now on the cluster only. Tried the 5 min hazard light fix but no change. Any ideas?
Old Feb 14, 2022 | 09:38 AM
jake24lt's Avatar
jake24lt
1. Turn Ignition on, but do not start the bike.
2. Turn on 4 way hazards by pressing the hazard button on the
controls.
Turn Signal Sync Procedure
3. Turn the Ignition off letting hazards run. IF the bike has security they
will flash 5 or 6 times and then pause. This is normal. They will go
back to flashing normal hazard mode.
4. Let hazards run 1-2 minutes.
5. Turn Ignition back on.
6. Turn off hazards.
7. Turn Ignition off and then back on.
8. Check function of both turn signals
Old Feb 14, 2022 | 10:19 AM
SoCalHarley
Thanks, I tried that one too from CD and same issue. I am thinking I'll need to have the dealer flash it for all LED lights.
Old Feb 14, 2022 | 11:24 AM
SoCalHarley
One more question.... Is the tribar on the rear fender already LED? Looks like it must be.
Old Feb 15, 2022 | 09:10 AM
jake24lt's Avatar
jake24lt
Yes it is. But in stock form, it is a running light only. You can buy one that that will do brakes as well.( custom dynamics) Some, have directionals as well. Not sure the directionals serve any purpose that low to the ground, unless you live in LA. (see low riders)
Old Feb 15, 2022 | 02:45 PM
SoCalHarley
Thanks the reason I ask is I am told the ECM can be flashed for "all LEDs". With the directionals replaced all lights on the bike now are LED. Hyperflash on the cluster still there so I guess this will need to be done.
