Removing or moving the heel shifter
Old Mar 15, 2022 | 08:32 PM
maxxym's Avatar
maxxym
Default Removing or moving the heel shifter
Any recommendations for extended heel shifter? I still have stock ones installed. I don't mind replacing them, but HD doesn't have ones I like. I noticed today that my floorboards are not lined up the best they could be. My left one on the shifter side is kind of back. When I place my foot on it, my feel touches the heel shifter and I could still have like 2 more inches to the back of the floorboards.
If I was going to remove the heel shifter (I use it sometimes, and the only reason why I keep it is in case I have an emergency break down with the toe one), but I wouldn't care if I removed it. If I did, do I need to also replace the part that the shifters mount on, or do I put some kind of spacer in there so it doesn't stick out as much?
Old Mar 15, 2022 | 08:54 PM
decencyxdefied's Avatar
decencyxdefied
Idk about the floorboard stuff but there are caps to cover the end of the spline if you take the heel shifter off
Old Mar 15, 2022 | 08:58 PM
Red's Avatar
Red
Buy the rubber OEM spacer from Harley for about two bucks! You can find it on '21 Touring models and some earlier.
Old Mar 15, 2022 | 09:18 PM
LoneBone's Avatar
LoneBone
^^^^^What he said^^^^^
They make chrome and black caps depending on what you have, to cover that spline.....
Old Mar 15, 2022 | 09:26 PM
brakeless's Avatar
brakeless
Google Search "Extended Heel Shifter Harley" and you'll find several. Some more expensive than others. But I'm sure you'll find what you're looking for.
Old Mar 15, 2022 | 10:18 PM
OkieBill's Avatar
OkieBill
Well here’s one for starters.
https://www.kuryakyn.com/products/70...er-shift-lever
Google is your friend 😉
Old Mar 15, 2022 | 10:20 PM
gonemad's Avatar
gonemad
‘20s and ‘19s too
Old Mar 15, 2022 | 10:26 PM
lp's Avatar
lp
Yup. Bunches of these all over ebay too.
https://www.ebay.com/itm/32401809869...3ABFBM4paSjPJf
Old Mar 15, 2022 | 10:27 PM
gonemad's Avatar
gonemad
Harley sells a good looking set like this extended 1” in both directions. 2” total
size 14 boot for frame of reference.
Old Mar 15, 2022 | 10:58 PM
TSheff's Avatar
TSheff
Never had a breakdown of a toe shifter. Rubber spacer, Chrome or Black cover or extended shifter, all good choices depending on what you truly want. I alway remove heel shifter. Some people have a tendency to be heavy on the heel and that has caused issues.
Best thing I did as far as floorboards go is the spacer kit that moves the boards out, I also have extended boards, and highway pegs level with my boards so I have lots of room to reposition while riding.
