Detachable tour pack
Old Mar 19, 2022 | 01:47 PM
Les0854's Avatar
Les0854
6th Gear
Default Detachable tour pack
For those that made your tour pack detachable, how do you hide all the wires? Before I invest the dollars I want to make sure it doesn't look like crap.
Thanks!
Old Mar 19, 2022 | 03:00 PM
Ssitruc's Avatar
Ssitruc
There are the same amount of wires after making it detachable as there were before
but seriously.... with tour pack on, run the wires where they were before. No more, or less visible than with it "fixed".
When the tour pack is off, coil up what stays on the bike and put it under the seat on top of the battery area.
Old Mar 19, 2022 | 03:10 PM
MyFavRk's Avatar
MyFavRk
I just purchased a tour pack for my road king , also got a run / turn / brake light for it . The wires run under the back rest and under the rear seat to the connector above the battery , I will just unhook it when it's off the bike , easiest way I could think of doing it .
Old Mar 19, 2022 | 03:13 PM
FlamedFXR's Avatar
FlamedFXR
I wrap mine around the post that holds the drivers backrest.
Old Mar 19, 2022 | 03:23 PM
WP50's Avatar
WP50
Op This works well
WP
Old Mar 19, 2022 | 08:10 PM
Les0854's Avatar
Les0854
6th Gear
There is enough room under the seat so the wires don't get crushed?
Old Mar 19, 2022 | 08:23 PM
gonemad's Avatar
gonemad
Yes
Old Mar 19, 2022 | 08:28 PM
Badbagger's Avatar
Badbagger
This, I have same for my Ultra quick detach setup.
Old Mar 20, 2022 | 07:59 AM
Circa58's Avatar
Circa58
I put a piece of Plexiglass on the bottom of the TP that sticks out @ 2.5" and it is cut on a radius to match the back of the seat.... and I cut slots in the Plexi that allow for velcro wraps to tighten everything down up against the TP
then you need to put the leather flap onto the lower and it covers the wires.
Old Mar 20, 2022 | 08:29 AM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
I have led run/brake/signal lights, led side marker lights, AirWing led brake lights, speakers and Aux plug all connected on my detachable tourpak. Once big plug to disconnect.
Easy-Peazy.
YB
