Alarm problem
Any suggestions will be appreciated, or if you could steer me to any existing threads with similar issues?
Thanks for reading.
Thrn without moving the bike, with the Fib in range, turn on the ignition. If you get normal ignition on…the the fob and RC reception is good. Most likely then the alarm module is bad..
Any sense in trying a new Alarm antenna first?
Thanks for the reply.
If the siren starts going off... and you have your fob, turn the ignition on... and the siren will stop, and reset... or better yet, turn the ignition on while moving your bike.
I don't know if it is by design, or just at that moment its not "seeing" the fob, so it chirps... but found it annoying enough, that I just turn the ignition on. I couldn't tell you if it did it before the siren was installed, but that was a few years ago and just the lights flashing wouldn't have been as annoying
