Alarm problem
Old Mar 24, 2022 | 03:46 AM
kojak's Avatar
kojak
Originally Posted by GalvTexGuy
He says he put fresh batteries in both fobs.
I know it’s very basic, make sure the polarity of the new batteries is correct.
Old Mar 24, 2022 | 04:52 AM
Eriklassic's Avatar
Eriklassic
Pay attention to interference... Like toll booths, radio antenna,... for example
Old Mar 24, 2022 | 02:02 PM
rideonva's Avatar
rideonva
Originally Posted by Onlydad
Does the alarm module itself have a battery? I installed an aftermarket horn to make the alarm process sound but the cheap horn I installed has no battery, I understand the OEM horns have a battery but mine does not. So I'm back to does the alarm module have a battery?
Any sense in trying a new Alarm antenna first?
Thanks for the reply.
As far as I know security module doesn't have a battery, siren (is that what you call horn ?) does and if I'm not mistaken when battery low in siren it will do three chirps.
Old Mar 25, 2022 | 09:01 AM
Onlydad's Avatar
Onlydad
Originally Posted by Ssitruc
I think mine does what you are describing... even if I have my fob in my pocket, it will chirp at me if I move my bike around with the ignition off (I have the HD siren), and if I continue moving the bike around with the ignition off the siren is going to get loud... or I can turn the ignition on, while I move it, and everything stays quiet.
If the siren starts going off... and you have your fob, turn the ignition on... and the siren will stop, and reset... or better yet, turn the ignition on while moving your bike.
I don't know if it is by design, or just at that moment its not "seeing" the fob, so it chirps... but found it annoying enough, that I just turn the ignition on. I couldn't tell you if it did it before the siren was installed, but that was a few years ago and just the lights flashing wouldn't have been as annoying
This makes the most sense to me. I'm too cheap to replace the alarm and I'd rather not remove it completely for now. If I do remove it I'll buy something cheap/aftermarket, at least then I could have piece of mind as well as after sale service without having to walk into the Stealership. Thanks to all who replied. It's certainly an odd issue.
Thanks again.
Sputter
2014-2024 Touring Models
11
Nov 16, 2021 07:20 AM
Mdpayne912
General Topics/Tech Tips
Jun 7, 2018 12:56 PM
HD_Rider
May 6, 2012 01:45 PM
harley1005
Apr 18, 2010 12:06 PM
trax123
Sep 15, 2006 11:17 AM
