Mounting on the high side, Big guy
Old Mar 23, 2022 | 08:21 PM
Bruce B's Avatar
Bruce B
6th Gear
Default Mounting on the high side, Big guy
Hope someone can answer this. I’m 6’1” and weigh 340. Want to mount from the high side to help ease some pain. Will the right side floorboard hold my weight? I just don’t want to try it and risk bending it or breaking it. Has anyone my weight tried it? I’ve got an 04 Ultra. Thanks in advance.
Old Mar 23, 2022 | 08:24 PM
kel03's Avatar
kel03
Welcome to the forums from Ontario, Canada. I can't see that being an issue !
Old Mar 23, 2022 | 08:26 PM
brakeless's Avatar
brakeless
Just don't lean back and pull it off the stand! Any way you can lean back and get your left leg over the saddle?
Old Mar 23, 2022 | 08:32 PM
gonemad's Avatar
gonemad
I’m 230 and just parking one hoof on the right board and leaning on it to pull up a sock or tie a bootlace can cause potential drama.
Old Mar 23, 2022 | 08:55 PM
TriGeezer's Avatar
TriGeezer
I’m also a high side mounter due to back issues. I’m a bit less than you, and am concerned my weight on the floor board might tip the bile over. So I don’t do it. I lift my left leg. And use my hand to pull my leg over by the cuff in my jeans.
Old Mar 23, 2022 | 10:35 PM
Jshopes's Avatar
Jshopes
Itll pick the bike up if you go low enough in a bend and not bend or break, I'd imagine you won't be an issue.
Old Mar 23, 2022 | 11:57 PM
NODYNA's Avatar
NODYNA
Motor officers mount from the right side and I've seen some big ones. With the handlebars turned all the way to the left you can safely mount the bike. Put your foot on the floorboard lean into the bike, don't pull on the bars just use it for balance swing your leg over. Done properly it should not be a problem.
Old Mar 24, 2022 | 04:42 AM
TracerBullet's Avatar
TracerBullet
Old Mar 24, 2022 | 04:51 AM
IronAss's Avatar
IronAss
Old Mar 24, 2022 | 06:05 AM
Bruce B's Avatar
Bruce B
6th Gear
Thanks everyone.. I'll try it and see what happens. I'm not worried about the actual action of doing it, just wanted to know if the floorboard could hold my weight. We will see.
