It all depends on if you are looking for a compressor to carry on your bike or if you are looking for something for the garage. I picked up this unit for carry on the bike.
I've got the same one. I works great and stays in the saddlebag. Now the zipper on the case, that's another story. It broke the third time I unzipped it...
To FLHT & Beeracuda,
Where did you get them? Looks simple enough for me to work, if it has a good set of instructions to read if I can not get it to work the first time around.
I found one this afternoon at Home Depot. Made by Husky 12V with a pressure gauge thatyou can set your desired pressure to- when it hits the mark it turns off. $19.99.. Worked well on my wife's car tires and the Road Glide
If you want one for the garage, Sears has one that puts out 125 psi, comes with hose and accessory kit. I paid 89.99 as a member of the Sears Tool Club. Normal price is 99.99 and is usually available. 1.5 HP, 3 gal tank, Direct Drive oil lubed pump. Part #15310.
I like that Slime air pump and will pick one up for the scoot.
