What a pain in the ***. Dealer did last oil change. I changed my oil this time but I can’t for the life of me get the oil filter removed. I even went to the dealer and got their own oil filter removal tool. The thing is so damn tight in there that when I crank on it, the whole tool skips over the filter.
What are my options? I would really hate to poke a hole and do the screw driver thing.
I mean, there is nothing else to? Righty tighty, leftie loosie…..correct?
Put the tool the dealer back onto the filter and take a square block of wood or something and bang the tool onto the filter good and tight. Then try it, probably come off then
Likely whoever did the last oil change used a wrench to tighten filter after they replaced it. Snug by hand only because if you tighten it with a wrench, you are facing exactly what you are dealing with now....
If socket style wrench is slipping on the end of the filter when you attempt to loosen it (yes, lefty loosey...) take a shop rag or piece of shop towel and place it over socket and then force it onto the end of the filter. The shop towel should tighten up the fit enough that it won't slip without considerable effort and hopefully that will allow you to crack the filter loose. I've dealt with this same issue in the past and it's worked for me.
sorry to say but if a proper filter wrench won't loosen the filter you don't have many options. The screwdriver is likely your next best option. I've actually torn the filter using a screwdriver and had to resort to using a pair of needle-nose vice-grips. If that hadn't of worked I'm not sure what my next step might have been. There is no need to tighten a properly lubed filter on installation more than a 1/4 turn by hand. The dealer should be doing this filter removal for you at no charge IMO
