Engine Oil Vheck
Old Apr 27, 2022 | 04:20 PM
Maurice1's Avatar
Maurice1
Default Engine Oil Check
Did anyone see a discrepancy with owners manual with cold vs hot check? States level should show midway on dipstick when cold as well as hot. Am I missing something?
Old Apr 28, 2022 | 01:09 AM
MotoJockey's Avatar
MotoJockey
I like to have my oil at the halfway point in the "Safe" zone when cold so when it gets hot and expands, it's not so full that I get oil coming out of my breather into my air filter, or actually blow the dipstick out of my '03 which makes one HELUVA mess. As long as you in the safe zone, cold or hot, you're good........ just don't over fill.
Old Apr 28, 2022 | 06:01 AM
decencyxdefied's Avatar
decencyxdefied
I'll check both sometimes before and after a ride just to see where im at. Ita seems to be a general consensus to run half a qt low to avoid the above mentioned issues.
Old Apr 28, 2022 | 06:35 AM
2500hdon37s's Avatar
2500hdon37s
... doesn’t the highest mark on the dipstick say “Hot full” or “Full hot”?
Old Apr 28, 2022 | 06:41 AM
Iceman24's Avatar
Iceman24
I'm still trying to figure out what a "Oil Vheck" is...
Old Apr 28, 2022 | 07:15 AM
Spartanden's Avatar
Spartanden
I believe the dip stick has markings for cold check and hot check. I run mine midway between full and add.
Old Apr 28, 2022 | 07:22 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Judging by the amount of posts on the forum about how to check the oil in a motorcycle, it is just short of rocket science.
Old Apr 28, 2022 | 08:01 AM
RKZen's Avatar
RKZen
For a hot motor, the oil could be between the ADD QT and FULL HOT marks. For a cold motor, my manual says oil should not be above the halfway point.
Old Apr 28, 2022 | 08:41 AM
Maurice1's Avatar
Maurice1
I get that, but when it's hot it is at max level. So when its cold it would show at low end, no? Why when hot you don't want at top level. Can't get higher.
Old Apr 28, 2022 | 08:43 AM
Maurice1's Avatar
Maurice1
Ha! Every time I put the c in place on edit and save, went back to v. Oh vell.
