Wanting more APE
Old May 4, 2022 | 10:31 AM
clackavosticus's Avatar
clackavosticus
Originally Posted by GalvTexGuy
You had the dealer pull them back 3-4” after you had them installed, didn’t you? If so, that will affect the height of the bars quite a bit.
Yes I did - so I wasn't reaching - I'm afraid it affected the height as you said.
Old May 4, 2022 | 11:12 AM
Wide06's Avatar
Wide06
The pullback will also have a big affect.
I have 2 Road kings with different 16" apes. There's a HUGE difference between them, all because of pullback.
(the pullback of the bend in the bars, not the angle they're mounted)
Old May 4, 2022 | 11:31 AM
Super Glidester's Avatar
Super Glidester
Wanting more ape? thats what she said...
Old May 4, 2022 | 04:09 PM
clackavosticus
When I measured with the tape I guess I didn't fully factor in the effects off pullback....
Old May 4, 2022 | 04:34 PM
RANGER73's Avatar
RANGER73
First you have to learn the proper way to peal a banana.
I had the stock 10”s on 4” risers Buckhorn’s
hated the angle of the buckhorn’s and the look of the tall risers.
went to 10” with 2” risers so the cables would work but I missed the 2”.
so I did 14” on the 2” risers and replaced the cables, put the wiring internal.
should have gotten the 16”.
the struggle is real.
Old May 5, 2022 | 12:07 AM
Kevin714's Avatar
Kevin714
I put 12" bars on my Wide Glide.
When I got my SG I put 14" bars on it. Their perfect for me.
Old May 5, 2022 | 06:03 AM
Nitrochicken's Avatar
Nitrochicken
I initially ordered 14’s for my RK. After receiving them and doing a little fitting and mocking up, I decided to go with 18’s.
Old May 5, 2022 | 06:55 AM
clackavosticus
I am definitely going to bite the bullet and swap out for 16" bars.
Old May 5, 2022 | 07:23 AM
lp's Avatar
lp
Before you do, spend some time researching bars with actual pullback, like the Wild1.inc bars. You may not need 16s...
https://wild1inc.com/bar-dimensions
https://wild1inc.com/browse-products...s-flhtcuk-flhx
chump0828
Jan 5, 2015 11:15 AM
SeniorChief56
Apr 10, 2011 07:14 PM
vindyl
Apr 28, 2008 04:45 AM
Richietattoo67
Aug 25, 2007 07:22 AM
drrandall1
May 28, 2007 12:02 PM
