Battery tender fused?
Old May 10, 2022 | 05:56 AM
CoolBreeze3646's Avatar
CoolBreeze3646
I have had that 5 amp fuse blow a couple of times, could not figure out the reason. My battery tender will just blink red looking like it was not hooked up. Mine will glow red when charging, green when charged and blink red when not hooked up.
Only reason I can figure is if I plug the tender in hot, it gets some sort of surge and blows the fuse. Once replaced it works correctly, has only happened twice since I got my trike in 2019.
Old May 10, 2022 | 06:33 AM
barneyboy's Avatar
barneyboy
The fuse for the battery tender is the 20A P&A fuse.
Old May 10, 2022 | 06:55 AM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
all the Deltran brand Battery Tenders I have ever used has an inline fuse holder with a 7.5 amp fuse installed.
Old May 10, 2022 | 08:19 AM
strych9's Avatar
strych9
^^This is correct.
Old May 10, 2022 | 04:15 PM
stro1965's Avatar
stro1965
My issue was the tender lead attached to the bike. It was the 20 amp accessory fuse, all is well again. It knocked out my tender lead, my amp, and my cigarette lighter that I know of. My fault, I must have messed up and blown the fuse. I also had about 6 different engine codes I had to clear. Apparently something important was unplugged when I powered up the bike, they were all related to lost comms. Thanks guys.
Old May 10, 2022 | 04:44 PM
barneyboy's Avatar
barneyboy
Originally Posted by stro1965
I was using it to test some lights last fall with a jumper, didn’t realize it was dead until today when I tried to test some new ones. Put a multi-meter on it and it showed nothing.
Curious, what were you using for a "jumper", and how was it attached to the factory tender connector?
Old May 10, 2022 | 04:52 PM
stro1965's Avatar
stro1965
I had a battery tender go bad last year so I cut off about 12" of the cord and exposed the wires on the cut end. So I can just plug it into my tender lead and I have a 12 volt power and ground for testing.
SC_Compact
Jan 30, 2025 05:49 PM
SeeNoSun
Jul 17, 2024 09:26 PM
NoKenDo
Dec 19, 2021 05:34 PM
oakmossy
2014-2024 Touring Models
17
May 29, 2018 01:53 PM
traildog
Oct 10, 2015 07:56 AM
