2003 electra running super lean.
Old May 17, 2022 | 09:08 AM
Chuckytaylor's Avatar
Chuckytaylor
Stage II
Default 2003 electra running super lean.
Ive got a 2003 electraglide that's got 5.25 direct drive S&S cams with a K&N filter with a set of SharkRoad slip on mufflers, and it's running lean. I've replaced the entire fuel system, the map sensor, and upgraded to the power commander 5 and it my dyno tech can not seem to get it to stop running super lean. My dyno tech told me that its running at 14.1-16.1 and no matter how much fuel he tryst to add to it it doesn't make a difference. I'm at a loss of what's going on with it. Could it be a possible failed ecm?
Old May 17, 2022 | 09:33 AM
Hawg Runner's Avatar
Hawg Runner
Maybe need to upgrade O2sensors? I don't know why your Dyno guy can't figure it out. Call the folks you got the tuner from and see if they can help, I kinda like Power Vision,
Old May 17, 2022 | 09:38 AM
Chuckytaylor
Stage II
It doesn't have O2 sensors on it. Yeah I don't understand why he can't figure it out either. He thinks it's either the ecm pin or even the ecm itself but isn't certain.
Old May 17, 2022 | 09:55 AM
Hawg Runner
Not sure what your fuel ratio should be, but I would pull your sparkplugs and see what they tell ya.
Old May 17, 2022 | 10:19 AM
2500hdon37s's Avatar
2500hdon37s
Most dyno tuners shoot for 13.1.
but you’re right. The plugs would at least be an indicator as to a false read, but it sounds like the tuner is getting the AFR readings from a sniffer connected to the dyno.
Old May 17, 2022 | 02:21 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
Fuel pressure out of the pump is? Taken at the take off point under the tank.
The reason I have 2008 head pipes on my 2003 bike is so I can have O2 sensors the tuner can read and self adjust.
If the pressure regulator is garbage, if there are split hoses in the tank, or any other reason why the bike is not delivering the volume or pressure required, you can change as many parts as you want or play with the tune all day long, you can't improve what is not there.
Old May 17, 2022 | 05:18 PM
svarnster's Avatar
svarnster
check / clean the breather element
Old May 18, 2022 | 12:54 AM
chief08's Avatar
chief08
check the fuel pressure
Old May 18, 2022 | 05:40 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Has it been checked with the Power Commander removed? There’s no lack of stories of them causing tuning problems.
smalls78
2014-2024 Touring Models
Aug 2, 2023 11:13 AM
BadDadFLTR
Apr 17, 2017 01:00 PM
mjonesjr84
Aug 5, 2015 10:18 PM
mholl
Jul 14, 2014 05:02 AM
Hawk40
Sep 10, 2013 04:00 PM
