Oil Pressure Sensor?
Old May 22, 2022 | 10:16 AM
Sleepydoc's Avatar
Sleepydoc
5th Gear
Default Oil Pressure Sensor?
Just got back from a long road trip yesterday on my 2017 FLHTK. Has about 32K Miles. Midway through the trip, my oil light came on at startup. I immediately checked the oil. It was fine. Light would then go off, sometimes after I restarted the engine several times. When it was on, the message screen said 'Check Oil". When it was off, the screen said "Oil OK". This happened about eight times over the course of about four days. While I was pretty confident I didn't have an oil leak, I was also pretty paranoid, being in the boonies for so long at a time. I must've checked the oil a dozen times. Probably lost more from wiping the stick, than I burned on the trip.
I had a service with an oil change a couple of weeks before, and rode the bike before the trip to make sure everything was fine. Also, had no problems the first 1500 miles of the trip.
I checked the Diagnostic codes and got P0522 and P0523 which is Engine Oil Pressure Sensor Low/High.
How big of a deal is this to fix? It happened to me right after I bought it new in 2017, so it was covered.
Ironically, my extended warranty ran out while I was on the trip. Karma, I suppose.
Old May 22, 2022 | 11:09 AM
Ridercoach0412's Avatar
Ridercoach0412
Oil pressure sender 74438-99A about $30-40 depending on where you get them. Lower price there is from Surdyke.
Sender torque 94-144 in/lb. If reusing sender, apply LOCTITE 565 THREAD SEALANT to threads.
It's pretty tight in there but you can get the job done without removing anything else. You will need a 1-1/6 open ended wrench.
cheers
Old May 22, 2022 | 11:11 AM
Hawg Runner's Avatar
Hawg Runner
Just replace the sensor, same happened here, no more problem.
Old May 22, 2022 | 01:26 PM
sanman4ever's Avatar
sanman4ever
I think I had to remove the heat shield when I replaced it in my ‘09
Old May 22, 2022 | 05:47 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
those senders are garbage, replace it and I bet the problem goes away
Old May 23, 2022 | 03:13 AM
slammed808's Avatar
slammed808
Stage II
Anyone know where they have an oem oil pressure sender (74438-99A) in stock? Don't buy the aftermarket ones, they're garbage...ask me how I know, lol. Harley says it's backordered for 11 weeks.
Old May 23, 2022 | 05:00 AM
IronAss's Avatar
IronAss
They're called idiot lights for a reason.
Install a pressure gauge.
Old May 23, 2022 | 05:35 AM
smitty901's Avatar
smitty901
Very common for them to fail.
Old May 23, 2022 | 05:55 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Ok, tell us the reason.
Adding an oil pressure gauge doesn`t eliminate the need for an electrical unit on the engine, unless you install a direct reading gauge on the engine (which is pretty much useless anyway).
Thy have been using oil pressure warning lights on Harleys for many decades.
Never do away with an oil pressure warning light, it may call your attention to a problem.
And how often will you look at that dark oil pressure gauge at night?
Old May 23, 2022 | 06:01 AM
IronAss's Avatar
IronAss
He can take it or leave it.
I stated my opinion and have no intention of getting into a pissing match with you or anyone else about it.
Good Day.
ETA. I have both the idiot light and a gauge on mine.
