Oil Pressure Sensor?
Old May 23, 2022 | 06:45 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by Ridercoach0412
Oil pressure sender 7443
The OP has a 2017 model, which is a different engine, and different oil pressure switch part number.
The correct part number is 71400112A
Old May 23, 2022 | 09:30 AM
Ridercoach0412's Avatar
Ridercoach0412
Sorry, you're right. Just replaced mine a few weeks ago, misread the year.
cheers
Old May 23, 2022 | 12:39 PM
Max Headflow's Avatar
Max Headflow
Couple things..
Don't put sealer on the threads if replacing the sending unit!! The M8s use a 1/2-20 straight thread and have an O ring seat. The sender should come with a new O ring. If not IIRC they are -013, use Viton..
Second. If using the original oil pump. you might want to replace it. IMO it's the pressure relief valve is not seating all the way. I have a 17 RK and have added a mechanical gauge, Occasionally when the motor gets real hot the oil pressure will start to fluctuate, sometimes the pressure light will come on and for some reason when it goes back to good pressure the light doesn't go off. It's likely either do to BCM ECM not sending out a message that the oil pressure is good or the message gets dropped.. This, IMO, was the reason for first oil pump change and not sumping.
Old May 23, 2022 | 03:15 PM
Sleepydoc's Avatar
Sleepydoc
5th Gear
Good info. Thanks!!!
maxxym
Sep 20, 2021 07:01 AM
Spurrs
Milwaukee Eight (M8)
36
May 26, 2018 08:53 PM
jacknthebox
Jun 15, 2013 06:46 PM
shy1
Aug 15, 2012 07:41 AM
FBFletch
Jul 10, 2006 12:00 PM
