Issue installing a jiffy stand spring
I have seen two different things, either people have a tab under the bike to mount the other side of the spring to or the whole in the frame. I am trying to figure if I just have the wrong size spring, a broken tab off the frame or my stand tab is bent which is causing the spring to have too much tension and bend the hooks. Appreciate the help!
PS my wife did
Hole on the frame
Tab that might be bent
Old vs new
the paint/artwork!
Check. You tube for video.
you loosen jiffy spring tab, move stand forward, unhook both end of spring, install new spring.
Make sure bike is on stand or someone is holding bike upright.
The HD jiffy stand springs show two part numbers for touring twin cams....
There's one part number for '99-'06 (#50112-99) and then another one for '07 to "16 (#49725-07A)..
Just maybe that tab might have come with a slight angle
Get your new spring and try it first
Just a opinion
kel03 has a 2010 bagger, which takes a different spring part number than yours.... it could stand to reason his tab might look/be different...
It would take a pretty hard curb hit, right on the jiffy stand, to bend that tab... I'd be looking to see if the Jiffy stand, the mounting, and basically make sure the entire jiffy stand pieces haven't been damaged, if the correct spring didn't work. I would also look into checking that I had the correct jiffy stand for my application..
I would replace parts before bending the jiffy stand to make it work... I know many people will "customize" something to make it work, and they are successful... But I'm not one of them. I would have to figure out why it's not working as designed.. and address it that way
Even if that tab got bent by some mishap, bending it back could weaken it... That jiffy stand is the only thing holding up your bike, when you walk away from it....
It would really suck if you weakened that tab, and then 6 months from now you put your bike on the jiffy stand, and it just fell right over....
