Weight Limits
Old May 30, 2022 | 12:05 PM
Ultra103's Avatar
Ultra103
I'm a big guy and my wife and I were often riding at around 1700 + Lbs with all the crap we'd take with us. I put a better tire on the back and the handling issues I was having were fixed without having to address rear suspension, still using the factory shocks. tire choice makes a huge difference.
Old May 30, 2022 | 03:23 PM
GalvTexGuy's Avatar
GalvTexGuy
Which “better tire”?
Old May 30, 2022 | 04:43 PM
Ultra103's Avatar
Ultra103
There are lots of opinions out there - use what you're comfortable with.
Old May 30, 2022 | 05:06 PM
GalvTexGuy's Avatar
GalvTexGuy
Great answer. That’s what I thought you would say. 🫤
Old May 30, 2022 | 05:07 PM
Rob175's Avatar
Rob175
Just IMHO.....that's too much weight. Suspension and brakes would be my greatest concern....ie: bottoming out and increased stopping distance.
At the very least immediately replace the shocks, brakes & rotors and new tires......and keep an eye on all of those.
Be safe!
Old May 30, 2022 | 06:05 PM
Jshopes's Avatar
Jshopes
do you drive a car every day? or ever? if so alot of cars have under 1000lbs of available payload. pickups have more payload, but cars arent made for many big people. did you just ignore it? im probably over on my weight ratings too when im 2 up, but by less. some of the shock companies sell shocks with higher spring rates to handle the weight better. theres nothing you can do to increase gvwr, but beefing up suspension will make it more bearable. personally, im trying to also make better choices for myself and cutting my bull sh#t intake. i need to do better but its tough.
and why on earth does anyone say "me thinks"?
Old May 30, 2022 | 08:23 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
IMHO you have pushed way past the published limits and the real life limits ( published plus safety factor)
I am a big guy myself, and when I put someone on the bike and we are still under the published weight limits, I can feel the extra weights effect on the braking, suspension, in the way the tires are acting, etc.
Would you ever be able to forgive yourself if she was hurt because the brakes took longer to stop than they were designed too.
Please don't take this the wrong way because I need to do the same myself ( my left hip is in agony from carrying too much weight so my diet starts tomorrow I swear) but now might be the time to try to drop some pounds so you can safely enjoy two wheels together. I can't fly anymore because my weight is 40 pounds over what the plane's weight and balance calculations will allow, and my CDL is now limited to in state only due to my being 40 pounds over weight.... so I am in a similar position.
As I said above, I am not trying to be unkind, I am genuinely concerned about your health and safety.
Sorry if I offended
Old May 31, 2022 | 08:20 AM
LQQK_OUT's Avatar
LQQK_OUT
@Ultra103 Can you at least share with us what the maximum load @ PSI is? I'm going to guess you are using a car tire.
Old May 31, 2022 | 08:33 AM
Ultra103's Avatar
Ultra103
1279 Lbs at 51 PSI for the particular one I run (Quatrac SL). There are a ton of choices, I was looking mainly at the 400 AA ratings since my wife has started riding her own bike. I run 36 PSI on my rear and 40 on the regular front.
Old May 31, 2022 | 09:25 AM
Neggy ZRXOA 5248
the tire load rating is just one consideration, there is weight on the bearings and a lot of other variables,, right down to the thickness of the metal in the frame
