Charging system replacement questions
Old Jun 14, 2022 | 05:57 AM
AndyinCT's Avatar
AndyinCT
Default Charging system replacement questions
Hey!
So my 1998 Ultra classic FLHTCUI with 43k miles stopped charging the battery the other day. Luckily I wasn't too far from home and was able to ride it back. After doing some testing I believe the stator isn't working.
With a charged battery at idle it only produces 12.5 (and dropping) volts across the battery terminals.
The stator is only producing a few amps AC at idle and there is no continuity to ground from the stator terminals.
So, I have a few questions before I proceed:
Does it make sense to replace the the voltage regulator, stator and rotor all at the same time?
I believe my setup on there is a 2 phase because it has 2 wires coming off the stator, is that correct? If so, can I replace it with a 3 phase system like this one?
https://www.jpcycles.com/product/382...harging-system
How many amps is the stock system? I see aftermarket systems in 32A, 38A, 40A, 50A, etc. I don't need any additional power when I replace these parts but I don't want less.
I'm gonna get after this myself so can anyone tell me if any special tools are needed? Pullers, etc?
Thank you!!
Old Jun 14, 2022 | 06:21 AM
glasspilot's Avatar
glasspilot
Originally Posted by AndyinCT
Hey!
A few years ago my 06 EG stopped charging and somewhere here I found info on how to determine what was wrong. I lucked out because it was a bad voltage regulator. Much easier fix than dealing with the stator. For what it's worth I found an aftermarket VR made in the USA, very high quality. Cycle Electric I think made in Ohio.
Do a search here for all the info you can find on this problem before you dig in. If you're lucky it will be just a VR trade out.
Old Jun 14, 2022 | 06:27 AM
Goose_NC's Avatar
Goose_NC
Look at cycle electrics for the parts. I've used them when the HD parts failed. They seem more resistant to breaking down in the heat.
As too special tools, you'll need to remove the outer primary, and then the clutch and counter sprockets. Need the ability to lock the two to remove and large sockets.
Old Jun 15, 2022 | 08:32 AM
hattitude's Avatar
hattitude
I am also a fan of Cycle Electric replacement parts.... Their site shows all '97-'98 FLH/FLT took OEM #29987-97 (38 amp) and their part number CE-3845-97... They have a dual amp rating on theirs at 38/48 .... not sure what that means... You could call them.
From their web site:
"Note: When replacing a stator on Evo and Shovel heads compare the plug type to see which system is currently being used. If in doubt replace the complete system as a set. Twin Cam models use the same plug on more than one system so comparing plugs won’t work."
Replacing the stator isn't hard, but it takes some time and effort.... I would strongly suggest getting the Factory Service Manual for your year/model before doing the job...
The trilogy of battery, stator, and voltage regulator are strongly linked and dependent on each other. If one fails, it can affect one or more of the other two. There is no need to replace all three, as each one can be tested to see if it is in good shape. When in doubt, it can't hurt to replace all three, just costs more money and time...
Good luck with your repair...
NOTE: you can get a brand new Service Manual (#99483-98) for your bike for $104.00 from Surdyke HD Online
Old Jun 15, 2022 | 08:37 AM
AndyinCT's Avatar
AndyinCT
thanks!
Any idea if the 3 phase system is a direct replacement for the 2 phase system if all the components (static, vr and rotor) are replaced at once?
Old Jun 15, 2022 | 08:54 AM
hattitude's Avatar
hattitude
thanks!
I believe they are either single phase or 3-phase, but I'm no expert....
I suspect they can, in many cases. The note I quoted from their web page suggests as much.... but that would be a question for someone more knowledgeable than I am about the various charging systems....
You could call Cycle Electric and ask them...
Old Jun 15, 2022 | 10:37 AM
Eastcoast Jim's Avatar
Eastcoast Jim
thanks!
Yes - you replace it all - I put a Cycle Electric 52 amp 3 phase in my 03 Road King - You should replace the stator, rotor and rectifier (regulator) all together anyway
Old Jun 15, 2022 | 11:37 AM
Lunchboxx's Avatar
Lunchboxx
Hey!
Thank you!!
Yes replace all. I did this on my 01 Rod Gle and Used the 50 Amp 3 phase Cycle electric kit.
Old Jun 15, 2022 | 02:24 PM
tdrglide's Avatar
tdrglide
Lots of good information on Cycle Electric Inc. website
Old Jun 17, 2022 | 01:08 PM
AndyinCT's Avatar
AndyinCT
Ok, thanks everybody!
I love the cycle electric stuff but it was pricey and I can't afford it now. And I want to ride!
So I went with the 40A (I believe my stock setup was 38) compufire kit for around $400.
Do I need to replace my main breaker (for a higher amp unit) or anything related to the fuse box when I install this kit?
