Cornering Clearance
Old Aug 14, 2007 | 11:44 PM
crock's Avatar
crock
Default Cornering Clearance
Is there a practical way to get more cornering clearance from a Road King?
Old Aug 14, 2007 | 11:46 PM
davewear's Avatar
davewear
Default RE: Cornering Clearance
raise the suspension or hang off when yer cornering
Old Aug 15, 2007 | 01:48 AM
crock's Avatar
crock
Will raising the suspension work? Are there problems with the belt angle or something similar?
Old Aug 15, 2007 | 01:53 AM
SoCal_Pappy's Avatar
SoCal_Pappy
They do make a kits to raise and move the floorboards forward a bit...
Old Aug 15, 2007 | 02:03 AM
davewear's Avatar
davewear
ORIGINAL: crock
why would the belt angle change? check http://www.progressivesuspension.com/for some longer shocks and springs for your forks.
Old Aug 15, 2007 | 09:45 AM
Zimbob's Avatar
Zimbob
Simple, raise the floorboards to the top notch. If that ain't enough, then longer shocks and fork tubes and springs are needed.
Old Aug 15, 2007 | 12:30 PM
davewear's Avatar
davewear
dont see how raising the floorboards will help, they move as u drag them and i can get into hard parts pretty easy with floorboards in the stock position.
Old Aug 15, 2007 | 01:08 PM
Neckball's Avatar
Neckball
Once you get past a certain point the mounting brackets begin to drag and the don't give. That's where the real problems can begin.
Old Aug 15, 2007 | 01:14 PM
The Vig's Avatar
The Vig
How far do you want to lay over? THis is a caddiliac like mototrcycle it's no busa. If you want to raise it so much that you can corner like a busa you will need a stepladder to get on.
What is scraping that you are worried about?
Kevin Painter
May 23, 2019 05:56 AM
Terrabella
Jul 20, 2012 07:49 PM
mellio157
Feb 3, 2010 08:07 AM
MyBluOx
Jun 30, 2009 11:30 PM
ssls6
EVO
May 27, 2007 02:46 PM
