Harley Boom Box Update
Old Jun 27, 2022 | 03:29 PM
Wolfmiester's Avatar
Wolfmiester
I have a simple 16GB thumb for the GTS upgrades only. Make sure it's the only thing on the Drive!
failed several times till I was told that..
Old Jun 27, 2022 | 04:30 PM
RiderX's Avatar
RiderX
Make sure your USB drive is not too large. Some newer, large capacity USB drives are not recognized by the GTS radio. I would suggest making sure it is 32 GB or less. As someone pointed out, it can be formatted using FAT32 or exFat, which is a format recognized by both Windows, Mac, and the GTS radio.
I usually plug in my USB drive before turning the ignition to the accessory position. It is quite possible that it will work after turning the bike to the accessory position but I have always connected the USB drive first.
Let us know if any of this helped you.
Old Jun 27, 2022 | 06:34 PM
asa1199's Avatar
asa1199
Be patient, it takes a little while to recognize the USB on mine.
Old Jun 28, 2022 | 12:36 PM
lefty33's Avatar
lefty33
Just did mine...super slick...no issues. Grabbed a 16GB SanDisk USB stick that I had. Checked to make sure there was nothing on it. Loaded the iso file on it, plugged it in to the bike, took about 5 minutes...done.
Old Jul 2, 2022 | 06:23 PM
Trk-35's Avatar
Trk-35
I too, am having problems up dating my 2021 FLHTK. I am using a formatted 16gb drive with nothing else on it. I don't see an "iso" file when I open the zip folder. I have 3 "DAT" files, 1 disc image file, and 1 text document file. Could I be downloading the wrong file from Harley?
Old Jul 2, 2022 | 06:41 PM
Maurice1's Avatar
Maurice1
Reason you don't show iso has to do with " file extensions" on PC. Forgot how I got there but you need to change to either hide or uncheck hide extensions. I think it's hide. Opposite of what you have now.
Old Jul 2, 2022 | 07:10 PM
Trk-35's Avatar
Trk-35
OK, I got it to update. I took Maurice1 advice and clicked the box "file extension". That put the "iso" after the file. I then transferred it to a formatted 16gb jump drive and plugged it into the bike. Lo and behold it worked!! Thanks for the help.
Old Jul 3, 2022 | 10:01 PM
skratch's Avatar
skratch
click on the start button, then type in 'folder options', when that opens, you'll go into 'view' and uncheck 'hide file extensions for known file types'
Old Jul 4, 2022 | 07:49 AM
Maurice1's Avatar
Maurice1
Thanks for that. After I posted above I did figure it out.
Old Jul 4, 2022 | 12:14 PM
skratch's Avatar
skratch
figured you did. mostly posted that so someone else in the future if they stumbled on this thread would have the info.
good that you got it figured out.
